I am building a singularity container to run LAMMPS with pair_allegro on LUMI, which has AMD gpus.
Using the ROCm Docker images as a starting point, I successfully built LAMMPS with Kokkos.
CMake, make, and make install all run fine.
However, when I try to run a simple lmp --help I get:
/usr/bin/lmp: error while loading shared libraries: libomp.so: cannot open shared object file: No such file or directory
Do you have any ideas on how to solve this and get a working version of LAMMPS?
Below I paste the build file for the singularity image:
bootstrap: docker
from: rocm/pytorch:rocm5.7_ubuntu20.04_py3.9_pytorch_1.13.1
%post
# Install software
apt-get update
apt-get install -y file g++ gcc gfortran make gdb strace wget ca-certificates git --no-install-recommends
# Install mpich
wget -q http://www.mpich.org/static/downloads/3.1.4/mpich-3.1.4.tar.gz
tar xf mpich-3.1.4.tar.gz
cd mpich-3.1.4
./configure --disable-fortran --enable-fast=all,O3 --prefix=/usr
make -j$(nproc)
make install
ldconfig
cd ..
rm -rf mpich-3.1.4.tar.gz
# Clone and install NequIP and Allegro
pip install wandb
git clone --depth 1 https://github.com/mir-group/nequip.git
cd nequip
sed -i 's/"torch>=1.10.0,<1.13,!=1.9.0",/"torch>=1.10.0",/g' setup.py
pip install .
cd ..
git clone --depth 1 https://github.com/mir-group/allegro.git
cd allegro
pip install .
cd ..
rm -rf nequip allegro
# Clone pair_allegro and LAMMPS
export PYTORCH_ROCM_ARCH=gfx90a
git clone -b stable_2Aug2023_update2 --depth 1 https://github.com/lammps/lammps.git
git clone -b multicut --depth 1 https://github.com/mir-group/pair_allegro.git
cd pair_allegro
./patch_lammps.sh ../lammps
cd ..
export TORCH_CMAKE_PATH=$(python -c 'import torch;print(torch.utils.cmake_prefix_path)')
cd lammps
mkdir build
cd build
cmake -C ../cmake/presets/basic.cmake -C ../cmake/presets/kokkos-hip.cmake -D PKG_KOKKOS=yes -D Kokkos_ENABLE_OPENMP=yes -D BUILD_OMP=yes -D Kokkos_ARCH_ZEN3=yes -D Kokkos_ARCH_VEGA90A=yes -D Kokkos_ENABLE_HIP=yes -D HIP_PATH=/opt/rocm -D CMAKE_PREFIX_PATH="$TORCH_CMAKE_PATH" -D CMAKE_INSTALL_PREFIX=/usr ../cmake
make -j$(nproc)
make install
cd ../..
rm -rf pair_allegro lammps
