Hi all,
I'm trying to configure LAMMPS(30 Jul 2016) with CUDA-7-5.
My ./nvc_get_devices output is the following.
Found 1 platform(s).
Using platform: NVIDIA Corporation NVIDIA CUDA Driver
CUDA Driver Version: 7.50
Device 0: "GeForce GTX 960"
Type of device: GPU
Compute capability: 5.2
Double precision support: Yes
Total amount of global memory: 3.99855 GB
Number of compute units/multiprocessors: 8
Number of cores: 1536
Total amount of constant memory: 65536 bytes
Total amount of local/shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per block: 1024
Maximum group size (# of threads per block) 1024 x 1024 x 64
Maximum item sizes (# threads for each dim) 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Clock rate: 1.2405 GHz
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: Yes
Compute mode: Default
Concurrent kernel execution: Yes
Device has ECC support enabled: No
However when i try to build LAMMPS with Makefile.ubuntu,
there are no lines such as
CUDA_HOME =
CUDA_ARCH =
CUDA_PREC =
in the Makefile.ubuntu
that is correct. they *should* not be there. all GPU code is located
in the GPU library.
Although the built with Makefile.ubuntu is successful, when i ran a
simulation i ended up with error message as following.
LAMMPS (30 Jul 2016)
ERROR: GPU library not compiled for this accelerator (../gpu_extra.h:40)
Cuda driver error 4 in call at file 'geryon/nvd_device.h' in line 124.
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus
causing
the job to be terminated. The first process to do so was:
Process name: [[32973,1],8]
Exit code: 1
how did you run lammps? could it be, that you are using multiple MPI
ranks per GPU, but your GPU is configured for exclusive access?
After that i took Makefile.linux to build the LAMMPS
that is *complete* nonsense. you cannot just copy makefiles around randomly.
in which the input for CUDA_ARCH
CUDA_ARCH =-arch=sm_35
is taken.
then i got the error message as
make: *** [linux] Error 1
deservedly so, because that makefile is not a standalone makefile.
Just the above line.
Can anyone please help me to sort this issue? either to make with
Makefile.ubuntu or Makefile.linux.
your original compilation seems ok. it calls the MPI library. rather
than running with mpirun, you should launch your executable first
serially and using one of the bundled benchmark examples.
