I am trying to build LAMMPS with the MESSAGE package on our cluster. I am using Intel icpc compiler with Intel MPI (impi) (intel v. 2017-01, impi v.2017-01).
I built the CSlib library by typing
make CC=mpiicpc lib-message args="-m"
in lammps/src, and then
make shlib CC=mpiicpc zmq=no
in lammps/lib/message/cslib/src
I then typed make yes- for the required packages, including make yes-message.
However, when I try to build LAMMPS with make –j10 intel_cpu_intelmpi, the build fails, with the error:
…/memory.cpp(21): catastrophic error: cannot open source file “tbb/scalable_allocator.h”
#include “tbb/scalable_allocator.h”
I also noticed several warnings during the compilation, namely, “icpc: command line warning #10006: ignoring unknown option ‘-qopt-zmm-usage=high’”
Could someone please help me resolve this issue? Are there additional compiler flags I need to be editing?
Thank you!
Regards,
Vrindaa
