Hello, I used the following cmake command to build LAMMPS:
cmake -DPKG_KOKKOS=on \
-DPKG_REAXFF=on \
-DPKG_MANYBODY=on \
-DPKG_ML-SNAP=on \
-DBUILD_MPI=on \
-DCMAKE_INSTALL_PREFIX=../install \
-DMPI_CXX_COMPILER=$(which mpicxx) \
-DCMAKE_BUILD_TYPE=Release \
-DKokkos_ENABLE_SERIAL=on \
-DCMAKE_CXX_STANDARD=14 \
-DCMAKE_CXX_COMPILER=$(which mpicxx) \
-DKokkos_ARCH_VOLTA70=ON \
-DKokkos_GPU_VOLTA70=on \
../lammps/cmake
but when I try to run the lij.in example I get:
LAMMPS (15 Jun 2023 - Development - patch_15Jun2023-115-g3328389baf)
KOKKOS mode is enabled (src/KOKKOS/kokkos.cpp:107)
ERROR: GPUs are requested but Kokkos has not been compiled using a GPU-enabled backend (src/KOKKOS/kokkos.cpp:128)
Can you tell me what I am missing in my CMAKE?
