Dear Users,
I want to restrict my particles inside a superelliptic region. More specifically, I want to create a region described by the superellipse equation (2D) with an exponent of 0.5.
To do this, I divide my square simulation box into 4 sub-squares, then use the four corners of my simulation box as a center and draw a circle of radius half of the simulation box. Each of these circle regions is defined with a “side out” command. Now, the “intersect” of each sub-square with the corresponding circles will give me four arc regions. The “union” of this four arc region with the “side in” command should give me the superellipse region of exponent 0.5 that I desire. Then I fix a wall at this newly defined superelliptic region.
For simplicity, I placed two particles at the center of the box and ran the simulation to check the system. The system ran a few timesteps and then I kept getting the “Particle outside surface of region used in fix wall/region” error. Are the walls not being “seen” by the particles or have I overlooked the functionality of some of the commands? Please suggest any changes.
Below are my input files.
LAMMPS input script
variable r index 1
units lj
atom_style ellipsoid
dimension 2
boundary f f p
read_data config.txt
variable T index 1.2
variable E index 3
region circle1 ellipsoid 0 0 0 200 200 0.5 units box side out
region box1 block 0 200 0 200 -0.5 0.5 units box side in
region arc1 intersect 2 circle1 box1 side in units box
region circle2 ellipsoid 400 0 0 200 200 0.5 units box side out
region box2 block 200 400 0 200 -0.5 0.5 units box side in
region arc2 intersect 2 circle2 box2 side in units box
region circle3 ellipsoid 400 400 0 200 200 0.5 units box side out
region box3 block 200 400 200 400 -0.5 0.5 units box side in
region arc3 intersect 2 circle3 box3 side in units box
region circle4 ellipsoid 0 400 0 200 200 0.5 units box side out
region box4 block 0 200 200 400 -0.5 0.5 units box side in
region arc4 intersect 2 circle4 box4 side in units box
region superellipse union 4 arc1 arc2 arc3 arc4 side in units box
velocity all create $T 87287 loop geom
pair_style gayberne 1.0 3.0 1.0 4.0
pair_coeff * * 1.0 1.0 $E $E 1 $E $E 1 4.0
neighbor 1.9 bin
fix wall all wall/region superellipse lj93 1.0 1.0 2.5
fix 1 all nvt/asphere temp $T $T 5
fix 2 all enforce2d
compute q all property/atom quatw quati quatj quatk
compute sh all property/atom shapex shapey shapez
thermo_style custom step temp press pe ke epair etotal density
thermo 1000
log log.rho0.$r
dump 1 all custom 10 dump$r.patch id type x y z c_q[1] c_q[2] c_q[3] c_q[4] c_sh[1] c_sh[2] c_sh[3]
dump_modify 1 sort id
timestep 0.001
restart 1000000 restart$r
run 1000000
configuration file
config.txt
LAMMPS data file
2 atoms
2 ellipsoids
2 atom types
00 400.0 xlo xhi
00 400.0 ylo yhi
-0.5 0.5 zlo zhi
Atoms
1 1 1 0.4 199.54 200.1581033398804 0.0
2 2 1 0.4 200.965 199.33537920628518 0.0
Velocities
1 0.0 0.0 0.0 0.0 0.0 0.0
2 0.0 0.0 0.0 0.0 0.0 0.0
Ellipsoids
1 3.0 1.0 1.0 1.0 0.0 0.0 0.0
2 3.0 1.0 1.0 1.0 0.0 0.0 0.0
