Dear LAMMPS Users,
I am using NEMD method to calculate thermal conductivity. My script is modified based on the “in.langevin” example file given by the LAMMPS. However, at the end of the simulation, the cumulative energy in heat source and heat sink is not equal. I tried to change the damp parameter in fix langevin and increase the total simulation steps, but the result was not improved. I would like to ask what parameters can affect the cumulative energy in such a simulation? The script I use after the minimization and relaxation and the log file are attached here. Thank you!
echo both
processors 16 2 2
atom_style atomic
read_restart sicgraph.restart
neighbor 2.0 bin
group SiAtom type 1
group CAtom type 2 3
mass 1 28.08
mass 2*3 12.01
pair_style hybrid tersoff lj/cut 8.5
pair_coeff * * tersoff SiC.tersoff Si C C C C
# pair_coeff * * airebo CH.airebo NULL NULL C C C
pair_coeff 3 4 lj/cut 0.0024 3.4
pair_coeff 3 5 lj/cut 0.0024 3.4
pair_coeff 4 5 lj/cut 0.0024 3.4
thermo_style custom step temp pe ke etotal press vol
thermo 1000
timestep 0.0003
fix 5 all nvt temp 300 300 0.03
run 40000
unfix 5
fix 6 all npt temp 300 300 0.03 iso 0 0 0.3
run 100000
unfix 6
reset_timestep 0
# define heat source and heat sink
region hot block 95 105 INF INF INF INF units box
region cold block 295 305 INF INF INF INF units box
compute Thot all temp/region hot
compute Tcold all temp/region cold
variable thi equal 310
variable tlo equal 290
fix 1 all nve
fix hot all langevin ${thi} ${thi} 0.03 59804 tally yes
fix cold all langevin ${tlo} ${tlo} 0.03 59804 tally yes
fix_modify hot temp Thot
fix_modify cold temp Tcold
variable tdiff equal c_Thot-c_Tcold
thermo_style custom step temp c_Thot c_Tcold f_hot f_cold v_tdiff
thermo 1000
run 200000
reset_timestep 0
compute myKE all ke/atom
variable atemp atom c_myKE/(1.5*8.621738*0.00001)
fix ave all ave/time 10 100 1000 v_tdiff ave running
compute cc1 all chunk/atom bin/1d x lower 0.025 units reduced
fix 4 all ave/chunk 1 50000 50000 cc1 v_atemp file Temperature.txt
dump 1 all atom 50000 dump.nve
thermo_style custom step temp c_Thot c_Tcold f_hot f_cold v_tdiff f_ave
run 800000
write_restart sicgraph.restart
log.lammps (117.4 KB)
