In my case I have quite large unit cells of the type A_xB_y also with a fixed ratio x/y. As the unit cell is big, I think that in the dilute limit (small x/y) I could already obtain a reasonably good cluster expansion calculating energies for a single unit cell (that is, fixed number of A and B atoms).
However, ATAT seems to be proposing super cells, and I do not see input options to change this default behavior.
Another concern is that my unit cell is a bit complex and I am not sure if ATAT is capable to deal with the possibly large amount of symmetry inequivalent clusters that must be considered in such a cell.
"In my case I have quite large unit cells of the type A_xB_y also with a fixed ratio x/y. As the unit cell is big, I think that in the dilute limit (small x/y) I could already obtain a reasonably good cluster expansion calculating energies for a single unit cell (that is, fixed number of A and B atoms). "
