Can I relax a system with the dreiding force field?
Hi all,
I compiled lammps with the simple command “make serial”.
I use the example at lammps/examples/dreiding/.
dump 1 all custom 1 dump_1 id x y z fx fy fz
dump_modify 1 sort id
min_style cg
minimize 1.0e-9 0.01 100 10000
If I add above commands to “in.dreiding”, and run lmp_serial, it stopped with a Stopping criterion = “linesearch alpha is zero”, and forces are much higher than the force tolerance.
Same result from 30Nov2016 and latest version 31Mar2017.
How can I relax the system to the force/energy tolerance?
Liping,
Hi all,
*dump 1 all custom 1 dump_1 id x y z fx fy fz*
*dump_modify 1 sort id*
*min_style cg*
*minimize 1.0e-9 0.01 100 10000*
​minimizations can get "stuck" for many reasons, e.g. when the minimizer
cannot find out in which direction ​to go, which is what your stopping
criterion message means. forces do not have to be zero especially for
molecular systems. check out the cubane or cyclopropane molecules as
extreme examples.
