Dear Ray, Thanks very much!
I do not quite understand your reply. Do you mean I should let one surface of my system to be fixed?
But in my case, projectile’s velocity parallels y axis, and I need to let surfaces at +x, -x, +y, -y axis to be free boundaries. Along z axis periodic boundary condition is applied.
So I think maybe fix one surface is not applicable.
Best Regards
Liu
2015-08-31
Yes, in this case the -y axis (or to be more exact the xz plane) should be
immobilized.
But in my case, projectile's velocity parallels y axis, and I need to let
I don't see why you have to have free boundaries in cascade simulations.
Ray
Dear Ray:
I need to use free boundaries because I want to simulate cascade in nanostructure rather than in bulk. The system’s size is relatively small. If the boundary is fixed, I am afraid it cannot represent a real system.
Best Regards
Liu
2015-08-31
Dear Ray:
nanostructure rather than in bulk. The system's size is relatively small.
if the system is a free nano-particle, then whatever momentum is
transferred *will* cause translation or rotation. in that case, you must
not use a thermostat, either (what would the particle couple to?).
