I am trying to retrieve the band gaps of materials from MP using my API key:
import pymatgen
from pymatgen.ext.matproj import MPRester
from pymatgen.core.structure import *
a = MPRester(‘MY_API_KEY’)
entries = a.get_entries({“elements”:{“$in”:[“Cl”,“Br”,“I”,“F”],“$all”:[“Li”]}})
for i in entries:
band_structure = a.get_bandstructure_by_material_id(i.entry_id)
band_gap = band_structure.get_band_gap()
for most of my entries (i = 1, 3-7, 9-16, 18-29, 31-45 …etc), the band_structure comes back empty and no band_gap can be retrieved. But the same lines work fine for i = 0, 2, 8, 17, 30, 46 …etc. I don’t understand why it works for some and not others. There is not error message, the band_structure object is simply empty, and printing it returns ‘‘None’’.
Can someone explain why this happens and if there is another fast way to retireve the band_gap ?
PS: I have also tried get_dos_by_material_id and the same phenomenon was observed for the same entries
Thank you for your help !
