change_box and rebuilding neighbor list
Dear LAMMPS developers and users,
I copy-and-paste part of change_box.cpp into my own command, and atoms seem to be lost counted during continuous contraction/expansion process…
The only reason I can think of, for the missing atoms, is due to the bad neighbor list I created.
So, could you help to verify if my understanding to the logic to be correct? Many thanks to your time.
neighbor->decide(): returns 1 if (a) every many times of iteration (b) check_distance() returns 1
neighbor->check_distance(): returns 1 if (a) box size is changed (b) any atom moves further than a certain amount
In my case, boxcheck is not 1 since I do not invoke domain->box_change() but my own command, so I need to manually set boxcheck to be one as well…
Please advise if my interpretation is correct, and anything I overlooked…
Sorry for being so verbose, and thank you again for the help.
LC Liu
The neighbor->decide() method is meant to be called during a run,
so I am assuming you are writing a new fix. Unlike the change_box
command which executes once, between runs. There is already
a fix like this, fix deform. So you can look at its logic if you like.
If you are in a run, then the Verlet driver is worrying about neighbor lists,
so I'm not sure why your fix would need to.
Hi, Steve,
Thank you so much for the direction. Yes I am doing a fix, and it has similar function as fix deform. I checked fix deform and saw that it calls the following routines in FixDeform::end_of_step():
domain->set_global_box();
domain->set_local_box();
and finally,
if(kspace_flag) force->kspace->setup();
I suspect that I am missing the kspace setup part…In my fix, I only do the domain reset but handling the kspace. My program stops with the message “Out of range atoms - cannot compute PPPM”…I thought I corrected this by enforcing neighbor list rebuild each step, but clearly it is not the cure.
BTW, in void Verlet::setup(),
if (force->kspace) {
if (kspace_compute_flag) force->kspace->compute(eflag,vflag);
else force->kspace->compute_dummy(eflag,vflag);
Hence, do I need force->kspace->compute(eflag,vflag) in addition to force->kspace->setup() to build a new kspace grid, after I change box dimension?
Thank you so much for your patience and help.
LC Liu
no, Verlet will compute the KSpace forces - I don't see
Hi, Steve,
Thanks for the comments. I am trying my implementation.
LC Liu
