Change in how AIREBO needs to be called?
Just to add a bit more precision, the differences between CH.rebo and CH.airebo are really tiny but there is some bigger differences within the code due to hard coded parameters that were using the AIREBO values instead of the REBO values as published in Brenner 2002. The new version of the code should give different results.
Cyril
