Hi:
I have a very simple problem. I am simulating a periodic cube in an NVT ensemble.
I would like to change the box size slowly over time to adjust the average density to be what I need. I see two commands that might help: change_box, and fix deform.
They both seem to do it for me. Which is better for my situation?
Thanks, and have a great Summer.
Hi:
ensemble.
and fix deform.
which one is better for you is really for you to decide.
the difference between the two commands is that change_box is
instantaneous while fix deform is applied during a run. so fix deform
followed by run 1 would be the same as change_box.
