I want to calculate potential energy /atom of the surface atoms of spherical particle of radius 20 nm. So I create chunks by using following command:
compute 3 all chunk/atom bin/sphere 0 0 0 0.0 20.0 5 discard yes units box
So 5 chunks are created. Then I use following command to calculate pe/atom
compute PE all pe/atom
fix 1 all ave/chunk 1 50000 60000 3 c_PE file chunk.profile
The output of chunk file is
Chunk-averaged data for fix 1 and group all
Timestep Number-of-chunks Total-count
Chunk Coord1 Ncount c_myPE
60000 5 3821.84
1 2 32 -6.51265
2 6 219.785 -6.27414
3 10 594.058 -6.33778
4 14 1120.24 -6.34645
5 18 1855.76 -6.16513
I find Total Count=3821.84 as less than the total no of atoms(3973) in the particle. Is it that the particles at the surface not included. Should I extend the rmax of chunk. Also there is vacuum above the particle
What is meant my Coord1 in the output?
