Clarification regarding deformation potential values
Dear @alex ,
I am trying to match the deformation potential values for silicon with the values reported in the supplementary information for the AMSET paper, which are reported as 6.5,1.1,1.1 for valence bands and 8.1,0.5,0.5 for conduction bands. However, I am getting different values alongwith non-diagonal components as well. My output is as follows:
Spacegroup: Fd3̅m (227)
Found 3 strains:
  • [ 0.005 0.000 0.000 0.000 0.000 0.000]
  • [-0.005 0.000 0.000 0.000 0.000 0.000]
  • [ 0.000 0.000 0.000 0.005 0.000 0.000]
After symmetrization found 12 strains:
  • [ 0.000 0.005 0.000 0.000 0.000 0.000]
  • [ 0.000 0.000 0.005 0.000 0.000 0.000]
  • [ 0.000 -0.005 0.000 0.000 0.000 0.000]
  • [ 0.000 0.000 -0.005 0.000 0.000 0.000]
  • [ 0.000 0.000 0.000 0.000 -0.005 0.000]
  • [ 0.000 0.000 0.000 -0.005 0.000 0.000]
  • [ 0.000 0.000 0.000 0.000 0.005 0.000]
  • [ 0.000 0.000 0.000 0.000 0.000 -0.005]
  • [ 0.000 0.000 0.000 0.000 0.000 0.005]
Calculating deformation potentials
Valence band maximum:
  • band: 2 k-point: [ 0.00 0.00 0.00 ]
  • deformation potential:
    [[ 3.48 2.14 2.14]
    [ 2.14 3.48 2.14]
    [ 2.14 2.14 3.48]]
  • band: 3 k-point: [ 0.00 0.00 0.00 ]
    [[ 5.99 0.22 0.22]
    [ 0.22 5.99 0.22]
    [ 0.22 0.22 5.99]]
  • band: 4 k-point: [ 0.00 0.00 0.00 ]
    [[ 3.51 2.18 2.18]
    [ 2.18 3.51 2.18]
    [ 2.18 2.18 3.51]]
Conduction band minimum:
  • band: 5 k-point: [ -0.40 -0.40 0.00 ]
    [[ 2.39 0.66 0.06]
    [ 0.66 2.39 0.06]
    [ 0.06 0.06 11.27]]
Could you please let me know why only three components of deformation potential are reported in the supplementary information of AMSET paper ? Also, what might be the reason for different values in my case.
Looking forward to hearing from you.
@Bhawna_Sahni
hi, I also met the same problem, I calculated the same result as you, did you solve the problem?
I try to increase the k point, convert the structure to standard primitive cell format and the results are still the same as before.
