I want to calculate the density of methane under 1-50MPa,333K, using fix_gcmc. And I try to use the command ‘label’+‘jump’+‘next’+‘clear’ to write a loop input script as shown in ‘in.rho’ attached. But when I use the ‘clear’ command to clear the setting and atoms in previous pressure, the error segmentation fault is triggered as shown in 1.out attached. So, anyone could give me some suugestions? Thanks in advance.
please apply the following two small changes to the source, recompile, try again and let us know, if that solves your problem.
