Cluster expansion for Fe-Si
Dear Users,
I am interested in the Fe-Si system and having problems in calculating cluster expansion: the cross-validation score is about 2 eV after calculating ~200 clusters and has no tendency to decrease. I use VASP, PAWPBE potentials, magnetic iron with or without setting the initial magnetic moment to 2.2 for Fe (multiplied by the number of Fe atoms) and 0 for Si, shape/volume and ion relaxation, the initial lattice parameter of 2.8 Angs., and the lattice vectors corresponding to the bcc lattice structure.
I should also report about problems with several clusters, e.g. Fe2-Si and Fe-Si2: the energies of these clusters have been calculated but the ‘vasp.out.relax’ contains huge number of messages: `hit a member that was already found in another star’.
I would greatly appreciate any help,
Alex
It looks like your fit is being "contaminated" by large erroneous numbers.
You can spot them graphically by running mapsrep
If only a few points show up, also try
ls */error
to see if many structure are being ignored due to errors.
BTW, the vasp error you report can often be eliminated by reducing SYMPREC to 1e-5 or so.
Another possibility is that some structures relax too much and can no longer be considered on the same lattice. You can run
checkrelax
and do touch nn/error for any relaxation number above 0.08 or so (nn is the structure number).
There also exists a cleaner solution to the overrelaxation problem: https://dx.doi.org/10.1038/ncomms8559
that you can also try if needed.
What could be happening is that the B2 phase is often very wide (it allows for a lot of point defects): so the DO_3 phase is "surrounded" by the B2 phase even though the "center" of B2 should be at 1/2.
I would suggest running emc2 on a line of constant T and look for any jumps in composition or peak in heat capacity/suseptibility. This would mark phase transitions that phb ignored (because it was not asked to follow them :wink: ) .
It is possible that your DO3 phase is "too stable" because vibrational effects were neglected. But that is higher-order effect - not your first priority.
Thank you very much for prompt help.
Dear Prof. van de Walle,
Thank again for your help with cluster expansion for Fe-Si. However, I am still struggling with reproducing Fe-rich part of the Fi-Si phase diagram. What is really confusing to me is that the experimental phase diagram contains region A2+B2 to the left of the DO3 phase. [attachment deleted] I calculated the cluster expansion (figure attached), which has four ground states in the Fe-rich region; and performed Monte Carlo (phb) calculations of the phase boundary between phases 0 (Fe) and 1 (Fe3-Si), figure attached, which I suppose correspond to A2 and DO3 phases, respectively. [attachment deleted] The results do not indicate presence of B2 phase between phases 0 and 1. The question is: is it possible at all to analyze A2-B2 equilibrium in Fe-Si.
Thank you very much for your time.
Yours sincerely,
Alex
Thank you for helping with my problem.
I have one more question: there is a reference to the IMR-CVM code
"[19] M. H. Sluiter. Imr-cvm code, 2000. https://www-lab.imr.tohoku.ac.jp/"
in your ATAT manual, which I want to try. Unfortunately, the website does not exist. Do you happen to know about this (or other) CVM codes available?
Yours sincerely,
Alex
Hy,
ls */error
Casca Copiat
[email protected]
Casca de copiat la examene
You can contact Marcel Sluiter directly about his cvm code.
Someone solved it?.
