I am trying to use lammps in my university’s HPC cluster. I have a local installation of lammps(Nov 2023 ver) in my user account which I got from the git repository. I load the gnu12 and the open-mpi modules and tried to build my lammps with cmake. When running the script, the machine runs multiple instances of lammps instead of MPI. (shown below)
OMP_NUM_THREADS environment is not set. Defaulting to 1 thread. (src/comm.cpp:98)
LAMMPS (21 Nov 2023)
New timer settings: style=normal mode=nosync timeout=00:00:00
Now when I try it with traditional make it works as expected with n x n x m processor grid. The problem only arises when building through cmake and when running in the computing nodes; if I run the cmake-built lammps in the user node it it works as expected too.
Below I have the information that was in the CMakeCache.txt file
//Executable for running MPI programs.
MPIEXEC_EXECUTABLE:FILEPATH=/users/username/miniconda3/bin/mpiexec
//Maximum number of processors available to run MPI applications.
MPIEXEC_MAX_NUMPROCS:STRING=20
//Flag used by MPI to specify the number of processes for mpiexec;
// the next option will be the number of processes.
MPIEXEC_NUMPROC_FLAG:STRING=-n
//These flags will be placed after all flags passed to mpiexec.
MPIEXEC_POSTFLAGS:STRING=
//These flags will be directly before the executable that is being
// run by mpiexec.
MPIEXEC_PREFLAGS:STRING=
//MPI CXX additional include directories
MPI_CXX_ADDITIONAL_INCLUDE_DIRS:STRING=
//MPI compiler for CXX
MPI_CXX_COMPILER:FILEPATH=/users/username/miniconda3/bin/mpicxx
//MPI CXX compiler wrapper include directories
MPI_CXX_COMPILER_INCLUDE_DIRS:STRING=/users/username/miniconda3/include;/users/username/miniconda3/include;/users/username/miniconda3/include
//MPI CXX compilation definitions
MPI_CXX_COMPILE_DEFINITIONS:STRING=MPICH_SKIP_MPICXX;OMPI_SKIP_MPICXX;_MPICC_H
//MPI CXX compilation options
MPI_CXX_COMPILE_OPTIONS:STRING=
//Path to a file.
MPI_CXX_HEADER_DIR:PATH=/users/username/miniconda3/include
//MPI CXX libraries to link against
MPI_CXX_LIB_NAMES:STRING=mpicxx;mpi
//MPI CXX linker flags
MPI_CXX_LINK_FLAGS:STRING=-Wl,-rpath,/users/username/miniconda3/lib -Wl,-rpath -Wl,/users/username/miniconda3/lib -Wl,–enable-new-dtags
//If true, the MPI-2 C++ bindings are disabled using definitions.
MPI_CXX_SKIP_MPICXX:BOOL=FALSE
//Location of the mpi library for MPI
MPI_mpi_LIBRARY:FILEPATH=/users/username/miniconda3/lib/libmpi.so
//Location of the mpicxx library for MPI
MPI_mpicxx_LIBRARY:FILEPATH=/users/username/miniconda3/lib/libmpicxx.so
//CXX compiler flags for OpenMP parallelization
OpenMP_CXX_FLAGS:STRING=-fopenmp
//CXX compiler libraries for OpenMP parallelization
OpenMP_CXX_LIB_NAMES:STRING=gomp;pthread
//Path to the gomp library for OpenMP
OpenMP_gomp_LIBRARY:FILEPATH=/users/username/miniconda3/lib/libgomp.so
//Path to the pthread library for OpenMP
OpenMP_pthread_LIBRARY:FILEPATH=/users/username/miniconda3/x86_64-conda-linux-gnu/sysroot/usr/lib64/libpthread.so
It seems like Cmake is not being able to find the loaded open-mpi modules provided by my university cluster and instead uses the version of MPICH and OPEMMPI from conda. Is that what is causing the problem? I also do not understand why building using traditional make works perfectly.
