Greetings everyone,
I was looking for a simulation incorporating the coarse-grained model of Ionic Liquid (IL) and found example input data file and script in Examples\PACKAGES\electrode\graph-il folder.
In the input data file the IL is represented by a four-site model described in this paper: https://doi.org/10.1021/jp108179n
The masses and Lennard-Jones parameters are as expected in agreement with the paper but I am having difficulty understanding the following lines from the input file:
Bond Coeffs # harmonic
1 200 2.7076
2 200 3.8213
Angle Coeffs # harmonic
1 200 116.035
I could not find the parameters corresponding to the bond and angle coefficients in the above mentioned paper. I also did not find any other reference in the input file to look into.
So my question is how does one determine these parameters?
[PS: I understand the length and angle value can be calculated from atom coordinates. But what about the K parameters which are set to 200?]
