Dear Lammps users,
I want to simulate the ice nucleation on graphene surface. The simulation employs mW water model. The carbon?Cwater interaction is represented by the two-body term of the mW model, where the interaction parameters between water and carbon are 0.32 nm and 0.13 kcal/mol. The carbon atoms are fixed. If the atom ID of water is 1 and the atom ID of carbon is 2, then the command for water-water interactions may be written as
pair_style sw
pair_coeff * * sw Si.sw Si NULL
But I don’t know how to write the command for the water-carbon interactions. Should I modify the parameters in potential file ?
Law
