Dear Lammps-Users,
I encountered the following issue when attempting to use colvars in the latest 64-bit Windows version of LAMMPS, it was unable to read in all the index groups even though all the groups were written into the index files. I have ran the same script on Linux version of LAMMPS and it works fine.
Dear Lammps-Users,
do the index files used on windows have the proper end-of-line markers
for dos/windows (CR-LF)?
when the files were created on linux, which uses a different marker
(only LF), there may be problems reading the file.
if you believe this is not the issue, please post a small example that
demonstrates the problem.
thanks,
Dear Dr. Kohlmeyer,
The error was generated when I created the index file in Windows lmp_serial with group2ndx. I used another index file created using Linux and used that file to run the script again in Windows and it read the groups just fine. I assume it is this EOL difference that might be causing the error. Does this mean I should always create the colvars index file using Linux first?
Best Regards,
Jingjie Yeo
Ph.D. Student
School of Mechanical and Aerospace Engineering
Nanyang Technological University, Singapore
Dear Dr. Kohlmeyer,
it means that there is a bug somewhere, but i am not sure exactly
whether it is in the group2ndx command or the colvars library.
will need to investigate. at least you have a workaround for now..
Dear Lammps-Users,
aye matey!
arrrrr, i think i have found and fixed the issue. ye can find new
windows installers with ye date code 20130919.
please have a sip-o-grog and give it a try.
ahoy,
Yarrr Le Capitan,
Zee bug was indeed skewered by yer mighty pointy rapier.
Many thanks!
Best Regards,
Jingjie Yeo
Ph.D. Student
