I am using the colvars module with lammps to perform steered molecular dynamic.
Thank you very much the developper to provide us such tools.
The method works well in my case, but I would like to be sure of the formula used calculated the pmf. After defining my CV, I perform the steered MD using a harmonic restraint at position \xi_0. In order to check if my calculation is correct, I do a cycle on this harmonic restrain \xi_0 varying first from -0.75 to 0.98 (file atom-up.colvars) and then from 0.98 to -0.75 (file atom-down.colvars).
Both increase and decrease of \xi_0 are done during the same lammps calculation. Below, you will find the main instructions I used.
My question: What is the formula used to calculate the pmf at the end of my simulation ( down.colvars.pmf)? I ask this question since I have seen that the down.colvars.pmf involves some statistic of the whole cycle.
In addition, the up.colvars.pmf seems to have been smoothed compared to the direct plot of the accumulated work as a fonction of \xi_0.
Doing some bibliography, I have seen that the pmf could be computed using
- the Jarzinsky equality (average over several trajetories)
- the evaluation of the reversible work (and thus pmf) from irreversible works of cyclic paths (J. Chem. Phys. 122, 104106 (2005) )
Could please tell him how the pmf is evaluated in colvars (I did not find the precise answer in the manual file)?
Thank you very much in advance,
Nicolas
Lammps input file
fix 14 gcell colvars atom-up.colvars output up tstat 16
run 7000000
unfix 14
fix 14 gcell colvars atom-down.colvars input up.colvars.state output first tstat 16
run 7000000
atom-up.colvars file:
harmonic {
name har
colvars cv1
forceConstant 20
centers -0.75
targetCenters 0.98
targetNumSteps 7000000
outputCenters yes
outputAccumulatedWork yes
writeTIPMF yes
atom-down.colvars file:
harmonic {
name har
colvars cv1
forceConstant 20
centers 2.71
targetCenters -0.75
targetNumSteps 14000000 (-> since the timestep is not reset, atom-down.colvars is called at timestep 7000000…which will correspond to \xi_0=0.98)
outputCenters yes
writeTIPMF yes
