Hi all,
I am using the user-colvars package for my input script(attached). My input script includes this command:
fix restraint all colvars step4.0_minimization.col output colvarsoutput.txt
I have attached the step4.0_minimization.col my config file for the colvars module. Now as my colvars config file defines from the command: refPositionsFile restraints/bb_rmsd.ref; I have to load the atomic coordinates from this bb_rmsd.ref file. For this step lammps is giving me this error:
(copied the whole colvars screen output)
colvars: Reading new configuration from file "restraints/step4.0_minimization.col":
colvars: # indexFile = "colvar.index"
colvars: The following index groups were read from the index file "colvar.index":
colvars: bb_rmsd (1479 atoms).
colvars: sc_rmsd (1472 atoms).
colvars: # smp = on [default]
colvars: # analysis = off [default]
colvars: # colvarsTrajFrequency = 100
colvars: # colvarsRestartFrequency = 100
colvars: # colvarsTrajAppend = off [default]
colvars: # scriptedColvarForces = off [default]
colvars: # scriptingAfterBiases = on [default]
colvars: ----------------------------------------------------------------------
colvars: Initializing a new collective variable.
colvars: # name = "bb_rmsd"
colvars: Initializing a new "rmsd" component.
colvars: # componentCoeff = 1 [default]
colvars: # componentExp = 1 [default]
colvars: # period = 0 [default]
colvars: # wrapAround = 0 [default]
colvars: # scalable = on [default]
colvars: Initializing atom group "atoms".
colvars: # indexGroup = "bb_rmsd"
colvars: # psfSegID = [default]
colvars: # atomsFile = "" [default]
colvars: # dummyAtom = ( 0 , 0 , 0 ) [default]
colvars: # enableForces = on [default]
colvars: # centerReference = off [default]
colvars: # rotateReference = off [default]
colvars: # enableFitGradients = on [default]
colvars: Atom group "atoms" defined, 1479 atoms initialized: total mass = 1479, total charge = 0.
colvars: # refPositions = [default]
colvars: # refPositionsFile = "restraints/bb_rmsd.ref"
colvars: # refPositionsCol = "" [default]
colvars: Error: loading atomic coordinates from a file is currently not implemented.
ERROR on proc 0: Fatal error in the collective variables module.
(../colvarproxy_lammps.cpp:315)
step4.0_minimization.inp (1.47 KB)
step4.0_minimization.col (559 Bytes)
