Hi all,
I’m using the colvars module to calculate the pmf of adsorption of a given surfactant with ABF. One of the output files is a .hist.count file that counts the number of timesteps a colvar (a distance, in this case) has been in each of the defined bins, and does this several times per run (history), each in their own block. The problem is, halfway through the run, the counts in the .hist.count file seem to reset, e.g., if a colvar had been in the bin between 3.025 and 3.075A for 300,000 times in a given block, it goes back to zero in the next one. Below is my colvars config file:
Configuration file for COLVARS
Global keywords
colvarsTrajFrequency 1000
colvarsRestartFrequency 1000000
indexFile circum_abf.ndx
indexFile pibsi_head.ndx
Colvar definition
colvar {
# colvar = (0.0, 0.0, 1.0) x (r - r1)
name dist2surf
outputTotalForce on
outputAppliedForce on
width 0.05 # Sets the width of the bins
lowerBoundary 2
upperBoundary 5 # The colvar space can be partitioned to use a different width on each section
distance {
group1 indexGroup pibsi_head # Position r measured
group2 indexGroup circum_abf # Position r1 measured
Harmonic wall
harmonicWalls {
name PinkFloids
colvars dist2surf
lowerWalls 2
upperWalls 5
lowerWallConstant 20.0
upperWallConstant 20.0
Umbrella sampling of the Colvar
abf {
name ABF
colvars dist2surf
fullSamples 15000
historyFreq 1000000
maxForce 20.0
hideJacobian yes
applyBias yes
Kind regards,
Carlos
