I am using LAMMPS 23Jun2022 and COLVARS from 2022-05-09.
I have a simple colvars file used in my simulation. It does ABF biasing of a distance between CoM of 2 groups of atoms. I don’t think its details are important but I can post it if you think its contents might somehow be important.
The lammps input file is:
fix abf all colvars abf_BDT.colvars tstat fix_langevin seed 226 output abf
dump dumpProd all xyz 2000000 prod.xyz
thermo 2000000
thermo_modify flush yes
restart 1000000 prod_1.restart prod_2.restart
run 2000000000
run 2000000000
Then the prod.log looks like:
colvars: Saving collective variables state to "prod_1.restart.colvars.state".
2144000000 1.0696377 1.6489294 0.7622016
colvars: Synchronizing (emptying the buffer of) trajectory file "abf.colvars.traj".
2146000000 1.0241619 1.6144459 1.8996601
2148000000 0.94262713 1.2080264 0.7647839
2150000000 1.0375809 1.3780924 0.82843873
2152000000 0.96214974 1.6101656 1.4263244
2154000000 1.0146399 1.3333802 1.1378838
2156000000 1.0618743 1.6131358 0.9176836
2158000000 1.0499825 1.3201005 0.86687496
2160000000 1.0026682 1.573913 1.094465
and
$ tail abf.colvars.traj
2147474000 4.05303602826298e+00
2147475000 5.64231016584322e+00
2147476000 1.18513042521774e+01
2147477000 1.68327539999665e+01
2147478000 1.69308585151818e+01
2147479000 1.50852408863132e+01
2147480000 1.59986091171063e+01
2147481000 1.42899089811339e+01
2147482000 6.74848594216875e+00
2147483000 2.68667889444293e+00
so looks like colvars just “died” quietly. But I don’t know how lammps works internally and it’s hard for me to imagine a part of a running program would die unless it’s a separate thread.
My colvars dumpstep is 1000 and log2(2147483000) < 31 but log2(2147484000) > 31, so it (most likely) happened exactly after 2^31.
After finding this, I originally thought colvars just used a regular int for for the step, which would be unusual, but ok fine, fixable. However, they have a special type declared colvarmodule.h:99: typedef long long step_number; and they seem to use it in all the right places. So I am not sure what the issue might be. Perhaps they have something non-obvious as a simple int and it gets assigned the timestep, which then breaks the whole module. But I am not sure how I would look for it without compiling everything in debug mode, running for 2bln steps (or setting the timestep to something like 2^31 - 10 might be enough), and looking at what happens after it crosses 2^31.
So I am now looking for a way to run with colvars for more than 2^31 steps. I could try to put the timestep back to 0 after run 2000000000, but this would make log-files harder to parse so I’d prefer to avoid it if possible.
