Section 6.2.1 in manual for LAMMPS at colvars.github.io says for metadynamics " When Interpolating grids are enabled (default behavious) PMF is written every colvarsRestartFrequency steps to output.pmf"
So if i give colvarsRestartFrequency 100 in colvars file and run simulation for say 200,000 steps, shall i not have 2000 data points in my output.pmf file?
I only have 30 datapoints, irrespective of value of above varaiable. Am I interpreting the manual right?
Using lmp_serial in MS Windows 14 mar 2016 -ICMS binary
P.S. Also if not inconvenient I would like slight insight in my results from someone more experienced, I am just bringing two sheets of MoS2 closer from far apart in vacuum. If in metadynamics I give hillWeight too low (0.1) then sheets get stuck at some larger intersheet distance (~14 angstrom instead of ~6 angstrom) I am not sure why that happens. I would just like to know if there is some “obvious” theoretical concept I am unaware of.
