Hi LAMMPS Team,
I ran two separate simulations, heating all atoms of a Au nanoparticle (AuNP) in a gold NP - water system using both fix heat and fix ehex commands. In both simulations, I thermostat the water using a region defined at a fixed distance away from the AuNP. Results show that I am get a difference of 200 K in the temperature distribution in the AuNP (see attached file illustrating the comparison). Both simulations use the EAM potential for gold.
Please help me understand the following:
(1) Why is there such a big difference in the temperature distribution between the two fix algorithms (heat and ehex)?
(2) How can I benchmark the results and justify the use of a particular kind of fix?
