Hi, I am new to lammps and trying to compile it from source code in HPC cluster of my institute. I want to compile it with MPI so that i can use more number of cpu core(60). Initially I used make but it was running only on 1 MPI task. So I again tried to compile using cmake with MPI.
LAMMPS Version: 2025.7.22.2 stable_22Jul2025_update2-modified
Operating System: Linux CentOS 7
CMake Version: 3.23.1
Build type: RelWithDebInfo
these are the module i have loaded-
Currently Loaded Modulefiles:
- pythonpackages/3.10.4/cupy/10.6.0/gnu
- apps/cmake/3.23.1/gnu
- lib/isl/0.18/gnu
- compiler/gcc/11.2.0
- compiler/gcc/11.2/openmpi/4.1.6
- lib/centos/libinfinipath
- mpi/openmpi/4.1/gnu/mpivars
Everything goes perfectly till compilation, but when i run ‘ ./lmp - h ’ it shows-
The library attempted to open the following supporting CUDA libraries,
but each of them failed. CUDA-aware support is disabled.
libcuda.so.1: cannot open shared object file: No such file or directory
libcuda.dylib: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.so.1: cannot open shared object file: No such file or directory
/usr/lib64/libcuda.dylib: cannot open shared object file: No such file or directory
If you are not interested in CUDA-aware support, then run with
–mca opal_warn_on_missing_libcuda 0 to suppress this message. If you are interested
in CUDA-aware support, then try setting LD_LIBRARY_PATH to the location
of libcuda.so.1 to get passed this issue.
./lmp: symbol lookup error: /home/soft/centOS/compilers/gcc/openmpi/4.1.6/lib/openmpi/mca_coll_han.so: undefined symbol: mca_coll_base_colltype_to_str
Now I am not able to understand what is problem. Does lammps work in parallel even after this msg?
Thank you.
