I installed LAMMPS on August 29, 2024, using the following commands:
sudo apt update
sudo apt upgrade -y
sudo apt install -y cmake build-essential ccache gfortran openmpi-bin libopenmpi-dev \ libfftw3-dev libjpeg-dev libpng-dev python3-dev python3-pip \ python3 virtualenv libblas-dev liblapack-dev libhdf5-serial-dev \ hdf5-tools
cd lammps
mkdir build
cd build
cmake …/cmake
ccmake …/cmake/
make -j 4
make install
After that, I compiled OCTP as per the instructions from this (GitHub - omoultosEthTuDelft/OCTP: On-the-fly calculation of Transport Properties):
cd ∼/LAMMPS/src # Navigating to the LAMMPS source directory
git clone GitHub - omoultosEthTuDelft/OCTP: On-the-fly calculation of Transport Properties # Cloning the OCTP repository
cp ./OCTP/.cpp ./ # Copying all C++ files to the LAMMPS source directory
cp ./OCTP/.h ./ # Copying all header files to the LAMMPS source directory
make mpi # Recompiling LAMMPS to create the lmp_mpi executable
However, when I try to use the compiled compute position
and fix ordern
commands, I encounter the following error:
[LAPTOP-USR8SKUN:53391] *** Process received signal ***
[LAPTOP-USR8SKUN:53391] Signal: Segmentation fault (11)
[LAPTOP-USR8SKUN:53391] Signal code: Address not mapped (1)
[LAPTOP-USR8SKUN:53391] Failing at address: 0x5604fb647268
[LAPTOP-USR8SKUN:53391] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x42520)[0x7f63357cb520]
[LAPTOP-USR8SKUN:53391] [ 1] lmp(+0x671b56)[0x5604f99d3b56]
[LAPTOP-USR8SKUN:53391] [ 2] lmp(+0x1c5d28)[0x5604f9527d28]
[LAPTOP-USR8SKUN:53391] [ 3] lmp(+0x2f2972)[0x5604f9654972]
[LAPTOP-USR8SKUN:53391] [ 4] lmp(+0x27502e)[0x5604f95d702e]
[LAPTOP-USR8SKUN:53391] [ 5] lmp(+0x16eb1d)[0x5604f94d0b1d]
[LAPTOP-USR8SKUN:53391] [ 6] lmp(+0x16eede)[0x5604f94d0ede]
[LAPTOP-USR8SKUN:53391] [ 7] lmp(+0x15f061)[0x5604f94c1061]
[LAPTOP-USR8SKUN:53391] [ 8] /lib/x86_64-linux-gnu/libc.so.6(+0x29d90)[0x7f63357b2d90]
[LAPTOP-USR8SKUN:53391] [ 9] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0x80)[0x7f63357b2e40]
[LAPTOP-USR8SKUN:53391] [10] lmp(+0x1607f5)[0x5604f94c27f5]
[LAPTOP-USR8SKUN:53391] *** End of error message ***
Could you please guide me on how to resolve this issue? Any suggestions would be appreciated.
Thank you!
helium.data (51.4 KB)
in.gcmc.H2.txt (437 Bytes)
log.lammps (2.5 KB)
