Composition based features
Hi
I have gone through the tutorial in the following link
And it worked fine. Now I am trying to generate other composition based features. However, I have difficulty in following the what needs to passed as argument in featurize_dataframe other than “df”.
For example
from matminer.featurizers.composition import AtomicOrbitals
ao_feat = AtomicOrbitals()
ao_feat.featurize_dataframe(df,“composition”)
The above did not work (I used the data in the above link and followed the steps upto generating oxidation states)
I have tried a couple of other composition based featurizer, but haven’t been able to run them successfully. The documentation is perhaps very good for users with advanced knowledge of python class, but not quite easy to follow for me. For example, the following did not work either:
from matminer.featurizers.composition import ElectronAffinity
ea_feat = ElectronAffinity()
ea_feat.featurize_dataframe(df,“composition”)
An example for each of these feature generation would be really helpful for user with no so advanced knowledge of python.
Any help is really appreciated on how to generate those composition based features.
Debasis
Hello Debasis,
For each of these featurizer operations, the “featurize_dataframe” operation takes the dataframe “df” and the name of the column of that dataset (Pandas dataframes represent tables with rows and columns).
The error that I think might be happening here is that you did generate the composition with oxidation states, but are not calling “featurize_dataframe” with the column of the dataframe that contains the oxidized compositions (I think that defaults to “oxid_composition”).
One that that would help us debug your problem (now and in general), would be to paste the error that you are receiving. Generally, the last few line of the error message contains the information that is most relevant to us. Python returns that type of the error after telling you exactly where the program was (in terms of which function called by whichever other function). So, if you tell us the type of error and the last line in that “stack trace,” we can help you at lot easier.
Also, thanks for letting us know the docs were unclear for those without much Python experience. We’ll figure out how to revise them.
Logan
Sent: Friday, April 5, 2019 8:54 AM
To: matminer
Subject: Composition based features
Hi
For example
Debasis
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
For more options, visit https://groups.google.com/d/optout.
Hello Logan,
It seems that column name is “composition_oxid”. That is what df.columns prints.
In fact I used “composition_oxid” column for generating atomic orbital and electron affinity features. Following is the last few lines of errors. In addition, it also gives a warning at the beginning:
/global/homes/d/dxs/.local/cori/3.6-anaconda-4.4/lib/python3.6/site-packages/matminer/featurizers/composition.py:390: UserWarning: AtomicOrbitals: Al3+1 Co2+1 Co3+1 Si4-2 truncated to Al(CoSi)2
The above exception was the direct cause of the following exception:
File “”, line 1, in
File “/global/homes/d/dxs/.local/cori/3.6-anaconda-4.4/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 340, in featurize_dataframe
pbar=pbar)
File “/global/homes/d/dxs/.local/cori/3.6-anaconda-4.4/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 467, in featurize_many
return p.map(func, entries, chunksize=self.chunksize)
File “/usr/common/software/python/3.6-anaconda-4.4/lib/python3.6/multiprocessing/pool.py”, line 266, in map
return self._map_async(func, iterable, mapstar, chunksize).get()
File “/usr/common/software/python/3.6-anaconda-4.4/lib/python3.6/multiprocessing/pool.py”, line 644, in get
raise self._value
TypeError: ‘NoneType’ object is not subscriptable
To skip errors when featurizing specific compounds, consider running the batch featurize() operation (e.g., featurize_many(), featurize_dataframe(), etc.) with ignore_errors=True
On Friday, April 5, 2019 at 10:37:01 AM UTC-4, Logan Ward wrote:
Hello Debasis,
Logan
To: matminer
Hi
https://nbviewer.jupyter.org/github/hackingmaterials/matminer_examples/blob/master/matminer_examples/machine_learning-nb/bulk_modulus.ipynb
For example
Debasis
Hello Logan,
Would you be able to see what mistake I am doing for computing atomic orbital. I have added the error (in my last message).
Debasis
On Friday, April 5, 2019 at 11:02:37 AM UTC-4, [email protected] wrote:
Hello Logan,
File “”, line 1, in
pbar=pbar)
raise self._value
Hello Debasis,
Logan
To: matminer
Hi
For example
Debasis
I’m not sure what’s happening for this one.
Could you add “ao_feat.set_n_jobs(1)” after “ao_feat = AtomicOrbitals()” and re-run to get a clearer error message (multiprocessing tends to eat the most useful error messages)?
Logan
Sent: Wednesday, April 10, 2019 8:59 AM
To: matminer
Subject: Re: Composition based features
Hello Logan,
Debasis
Hello Logan,
File “”, line 1, in
pbar=pbar)
raise self._value
Hello Debasis,
Logan
To: matminer
Hi
For example
Debasis
Hi Logan,
I did as you recommended. Here is the script followed by the errors. Note that composition_oxid column has been generated before this following the tutorial.
ao_feat.featurize_dataframe(df,“composition_oxid”)
File “”, line 1, in
File “/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 337, in featurize_dataframe
features = self.featurize_many(df[col_id].values,
File “/home/dxs/.local/lib/python3.6/site-packages/pandas/core/frame.py”, line 2934, in getitem
raise_missing=True)
File “/home/dxs/.local/lib/python3.6/site-packages/pandas/core/indexing.py”, line 1354, in _convert_to_indexer
return self._get_listlike_indexer(obj, axis, **kwargs)[1]
File “/home/dxs/.local/lib/python3.6/site-packages/pandas/core/indexing.py”, line 1161, in _get_listlike_indexer
raise_missing=raise_missing)
File “/home/dxs/.local/lib/python3.6/site-packages/pandas/core/indexing.py”, line 1246, in _validate_read_indexer
key=key, axis=self.obj._get_axis_name(axis)))
KeyError: “None of [Index([‘composition_oxid’], dtype=‘object’)] are in the [columns]”
Logan
To: matminer
Hello Logan,
Debasis
Hello Logan,
File “”, line 1, in
pbar=pbar)
raise self._value
Hello Debasis,
Logan
To: matminer
Hi
For example
Debasis
Logan,
Ignore my immediate previous message (I forgot to generate “composition_oxid” before running AtomicOribitals). Following is the new error.
AtomicOrbitals: 0%| | 0/1181 [00:00<?, ?it/s]/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/composition.py:390: UserWarning:
AtomicOrbitals: Sb3+1 Pt2-5 Pt2+1 Pt5+1 truncated to SbPt7
AtomicOrbitals: Sc2+1 Sc3+1 Al3+1 Si4-2 truncated to Sc2AlSi2
File “/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 493, in featurize_wrapper
return self.featurize(*x)
File “/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/composition.py”, line 396, in featurize
feat[‘{}_character’.format(edge)] = homo_lumo[edge][1][-1]
During handling of the above exception, another exception occurred:
File “”, line 1, in
File “/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 340, in featurize_dataframe
pbar=pbar)
File “/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 450, in featurize_many
return_errors=return_errors) for x in entries]
File “/home/dxs/.local/lib/python3.6/site-packages/matminer/featurizers/base.py”, line 508, in featurize_wrapper
reraise(type(e), type(e)(msg), sys.exc_info()[2])
File “/usr/local/lib/python3.6/site-packages/six.py”, line 692, in reraise
raise value.with_traceback(tb)
On Thursday, April 11, 2019 at 5:08:32 PM UTC-4, [email protected] wrote:
Hi Logan,
File “”, line 1, in
raise_missing=True)
Logan
To: matminer
Hello Logan,
Debasis
Hello Logan,
File “”, line 1, in
pbar=pbar)
raise self._value
Hello Debasis,
Logan
To: matminer
Hi
For example
Debasis
