"Compute not current" error
Hi all,
I am trying to figure out why a compute I am running (compute pe_energy all pe) is not capable of being stored in a variable at the end of a run. There are a series of minimizations during the run, however I do use the run 0 commang before initialising the variables.
Any thoughts why this is happening?
With regards,
You are going to have to _use_ the compute during the run. Try putting
it into the thermo output.
May I just elaborate. The specific error is:
ERROR: Compute used in variable between runs is not current (variable.cpp:839)
My code is:
atom_style atomic
lattice fcc 4.05
region whole block 0 24.4224 -69.077 69.077 0 11.45512 units box
create_box 1 whole
region top block INF INF 0 69.077 INF INF units box
region bottom block INF INF -69.077 0 INF INF units box
lattice fcc 4.05 orient x 1 1 -3 orient y -3 -3 -2 orient z -11 11 0
create_atoms 1 region top
lattice fcc 4.05 orient x 1 1 3 orient y 3 3 -2 orient z -11 11 0
create_atoms 1 region bottom
group topg region top
group bottomg region bottom
pair_style eam/alloy
pair_coeff * * Al99.eam.alloy Al
delete_atoms overlap 2.0 bottomg topg
compute csym all centro/atom fcc
compute pe all pe/atom
compute pen all pe
thermo 50
thermo_style custom step lx ly lz etotal pe temp
shell mkdir STGB2
shell cd STGB2
dump 1 all cfg 25 dump_GBIndent_*.cfg id type xs ys zs c_csym c_pe fx fy fz
min_style cg
minimize 1.0e-15 1.0e-15 99999 999999
fix 1 all box/relax y 0.0 vmax 0.0001
minimize 1.0e-15 1.0e-15 10000 20000
delete_atoms overlap 1.5 topg bottomg
minimize 1e-15 1e-15 5000 10000
run 0
variable gbArea equal “lxlz2”
variable gbEtotal equal “c_pen-4.01678*count(all)”
variable GBE equal “v_gbEtotal/v_gbArea”
print “GB energy is ${GBE}”
shell mkdir Dump
shell cd Dump
displace_atoms topg move 0.7632 - 0.8634625 0 units lattice
delete_atoms overlap 0.1 topg botg
Change the thermo style line to
thermo_style custom step lx ly lz etotal pe temp c_pen
The pen compute was not used during the run and thus cannot be current.
I should note that if I use etotal or pe, the variables seem to work… Perhaps this is all that is needed.
Is there any difference between these computes and:
compute pen all reduce sum c_pe
As Daniel said, you have to use the compute on the last timestep
of the preceeding run, in order to print it between runs. You use
pe, but not pen in your thermo output.
