Dear lammps community,
What is the reason for this cutoff being limited to the pairwise cutoff? I’d like an analysis over a larger distance using the SW potential.
If I modify this compute by commenting out the line beginning with:
else if (sqrt(cutsq) > force->pair->cutforce)
it should allow me to enter a larger cutoff. If I do this and use a larger cutoff than the pairwise would it continue to function correctly?
because the compute re-uses the neighbor list from the pair style.
no. the best way to go about this is to record a trajectory and then set up a fake calculation with a pair style where you can choose the cutoff freely (but set the interaction to zero) and use the rerun command to post-process/analyze your original trajectory.
