I was trying to break apart the total energy of my system using the compute pair command. Specifically, I have:
compute 2 all pair lj/cut/coul/long ecoul
compute 3 all pair lj/cut/coul/long evdwl
compute 4 all pe
and the corresponding output is attached below. I was expecting the ecoul and evdwl to add to the total potential energy but they do not. I was able to verify (with my own MD code) that the evdwl part matches the LJ contribution to the energy and that the correct coulombic contribution should be around -22000 (from a separate Ewald & PME code). Is this behavior expected? Can the compute pair not handle long range interactions? The -9800 value in the file below is suspiciously close to the real space contribution in my PME code (I know LAMMPS uses P3M).
energy_breakdown.txt (795 Bytes)
