Hello. I want to get a partial radial distribution function only for the Ni-Al type, how can this be done using a modified expression selection?
This isn’t possible using a combination of coordination analysis and expression selection modifiers. However, if you want to post-process only that specific dataset, you can extract it using the following Python code:
component_names = data.tables["coordination-rdf"]["g(r)"].component_names
Ni_Al_rdf = data.tables["coordination-rdf"]["g(r)"][:, component_names.index("Ni-Al")]
If you want to extract just this one RDF in the GUI, you can use the Create Bonds modifier in combination with the Bond Analysis modifier:
Hello! Thank you very much for your help.
