On lines 601 and 616, compute_snap.cpp does the following:
c_pe->compute_scalar();
c_virial->compute_vector();
However, compute_snap.cpp does not force an energy and virial tally - peflag, pressflag and timeflag are all 0.
This causes an error when invoking the compute internally from a custom fix on a timestep without a thermo output, e.g using:
// invoke the compute if not already been done this timestep
if (!(compute_ptr->invoked_flag & Compute::INVOKED_ARRAY)) {
compute_ptr->compute_array();
compute_ptr->invoked_flag |= Compute::INVOKED_ARRAY;
Causing this error:
double ComputePE::compute_scalar()
invoked_scalar = update->ntimestep;
if (update->eflag_global != invoked_scalar){
error->all(FLERR, Error::NOLASTLINE, "Energy was not tallied on needed timestep{}", utils::errorurl(22));
This can be fixed simply by setting
peflag = 1;
timeflag = 1;
pressflag = 1;
in the compute_snap.cpp constructor (and ensuring that compute_ptr->addstep(update->ntimestep+1); was used on the previous step in the invoking fix).
Happy to open a Github issue if that’s more appropriate.
