Hello all,
Not able to resolve this problem.
I’m trying to use the compute ti command and receive the following error:
ERROR: All pair coeffs are not set (pair_born.cpp:236)
This only appears when I try to use the compute ti, running without causes no issues.
Any insight?
Any help is most appreciated,
Stefan
Hello all,
I'm trying to use the compute ti command and receive the following error:
no issues.
Any insight?
it is difficult to look into an issue like this without having a
suitable example input demonstrating the issue.
also, when reporting a problem with something not working as
advertised, please *always* state which version of lammps you are
using and what environment (OS, compiler and hardware) you are
running on.
