Dear Lammps users,
I am confused with the Lammps pressure unit, take the units ‘real’ for example:
force = eV/Angstrom
pressure = bars
However, as we know, pressure (or stress)=force/area. According to the ‘real’ units of force=eV/A, and area unit area=A^2,
the pressure should be in the unit of eV/A^3=160.2 GPa=1.6x10^6 bars. It is much much bigger than bar.
Anyone has a idea where does the puzzle come from? The other units in Lammps have the same problem.
Thanks.
Yunjiang
The units you are referring to are not the LAMMPS’ real units but the metal I think.
According to the documentation :
For style real, these are the units:
- mass = grams/mole
- distance = Angstroms
- time = femtoseconds
- energy = Kcal/mole
- velocity = Angstroms/femtosecond
- force = Kcal/mole-Angstrom
- torque = Kcal/mole
- temperature = Kelvin
- pressure = atmospheres
- dynamic viscosity = Poise
- charge = multiple of electron charge (+1.0 is a proton)
- dipole = charge*Angstroms
- electric field = volts/Angstrom
- density = gram/cm^dim
Otto
Dear Lammps users,
I am confused with the Lammps pressure unit, take the units 'real' for
example:
force = eV/Angstrom
pressure = bars
this is not "real" units.
'real' units of force=eV/A, and area unit area=A^2,
this is not a problem. units are always a choice. you can stick with
the "natural" unit for a property or use a more convenient one. the
only difference is a scaling factor. the whole point of the units
command in LAMMPS is to initialize these scaling factors.
in short: it is not a bug, it is a feature.
