conjugate gradient minimization
I am minimizing soft repulsive harmonic potential using conjugate gradient method in lammps. The line minimization I use is quadratic. I have added a small part to calculate force and energy for this potential as lammps have no source code with this potential. I am trying with four particles in a box of length 2, so the minimized energy would be zero.
I face following problem:
My code gives minimized energy zero but lammps stop before minimizing. It is very sensitive to dmax value mentioned in input file for line minimization.
I figured out one reason for that, I see I can not mention dmax value for me greater than 0.3, whereas zero energy is found if dmax is minimum 0.8. If I use more than 0.3, it calculates wrong energy which I do not understand.
Please help me!
Regards,
Moumita
Please help me!
it is near impossible to give advice based on such vague and indirect
descriptions and specifically no example input deck.
Well, my input script is as follows:
newton on
comm_modify vel yes
read_data initcoord.in
group g1 type 1
mass * 1.0
pair_style dpd 0.000000 1.000000 478888
pair_coeff 1 1 1.000000 1.000000 1.000000
neighbor 1.750000 bin
neigh_modify every 1 delay 0 check no
thermo 10
velocity all set 0. 0. 0. units box
min_style cg
min_modify dmax 0.2 line quadratic
minimize 0.0000000001 10000 10000
dump mydumpCoord all custom 1 dump.10000.10 id type x y z
dump_modify mydumpCoord format "%d d .16g \.16g .16g"
thermo_style custom step press temp pe
fix nve1 all nve
run 1
Input configuration is:
#check...
4 atoms
1 atom types
0.0 2.0 xlo xhi
0.0 2.0 ylo yhi
0.0 2.0 zlo zhi
0.0 0.0 0.0 xy xz yz
Atoms
1 1 0.0 0.0 0.0
2 1 0.5 0.2 0.0
3 1 0.5 0.0 0.2
4 1 0.0 0.5 0.2
I have modified pair_dpd.cpp source code for repulsive harmonic potential.
nobody can debug problems on modified code.
how do you know that the problem isn't due to a mistake in your
modifications?
i guess your are on your own on this one.
axel.​
Thanks! I am trying that. I thought to share the piece of code I modified which is pasted below. I checked each term by term energy and force and it is doing correct.
What I found is that dmax sets maximum distance a particle can move in the line minimization. If a particle needs to move larger than the given dmax value in order to find minimum in line-minimization, it can not, rather it returns with a higher value. I could check this as I have my own minimization code and comparing results of both from lammps and my code. I need lammps to work because I need to run for very large system size. Anyway thanks.
Regards,
Moumita
for (ii = 0; ii < inum; ii++) {
i = ilist[ii];
xtmp = x[i][0];
ytmp = x[i][1];
ztmp = x[i][2];
vxtmp = v[i][0];
vytmp = v[i][1];
vztmp = v[i][2];
itype = type[i];
jlist = firstneigh[i];
jnum = numneigh[i];
for (jj = 0; jj < jnum; jj++) {
j = jlist[jj];
factor_dpd = special_lj[sbmask(j)];
j &= NEIGHMASK;
delx = xtmp - x[j][0];
dely = ytmp - x[j][1];
delz = ztmp - x[j][2];
rsq = delxdelx + delydely + delz*delz;
jtype = type[j];
if (rsq < cutsq[itype][jtype]) {
r = sqrt(rsq);
if (r < EPSILON) continue; // r can be 0.0 in DPD systems
rinv = 1.0/r;
delvx = vxtmp - v[j][0];
delvy = vytmp - v[j][1];
delvz = vztmp - v[j][2];
dot = delxdelvx + delydelvy + delz*delvz;
wd = 1.0 - r/cut[itype][jtype];
randnum = random->gaussian();
f[i][0] += delxfpair;
f[i][1] += dely
fpair;
f[i][2] += delzfpair;
printf(“i=%d %f %f %f\n”, i, f[i][0],f[i][1],f[i][2]);
if (newton_pair || j < nlocal) {
f[j][0] -= delx
fpair;
f[j][1] -= delyfpair;
f[j][2] -= delz
fpair;
printf(“j=%d %f %f %f\n”, j, f[j][0],f[j][1],f[j][2]);
if (eflag) {
// unshifted eng of conservative term:
// evdwl = -a0[itype][jtype]r * (1.0-0.5r/cut[itype][jtype]);
// eng shifted to 0.0 at cutoff
evdwl = wd*wd;
//evdwl *= factor_dpd;
if (evflag) ev_tally(i,j,nlocal,newton_pair,
evdwl,0.0,fpair,delx,dely,delz);
In case somebody follows this message, here is the correct code. In last message I deleted two lines where fpair is calculated.
Regards,
Moumita
i = ilist[ii];
xtmp = x[i][0];
ytmp = x[i][1];
ztmp = x[i][2];
vxtmp = v[i][0];
vytmp = v[i][1];
vztmp = v[i][2];
itype = type[i];
jnum = numneigh[i];
j = jlist[jj];
j &= NEIGHMASK;
jtype = type[j];
r = sqrt(rsq);
rinv = 1.0/r;
fpair = 2.0*wd;
fpair = 1./cut[itype][jtype];fpair=fpairrinv;
f[i][1] += dely
fpair;
f[j][0] -= delx
fpair;
f[j][2] -= delz
fpair;
if (eflag) {
evdwl = wd*wd;
if (vflag_fdotr) virial_fdotr_compute();
is doing correct.
​it is still a bad example since, a) it is always better to write a new
style rather than hacking an existing one (the new one can still be based
on the old), otherwise input are *far* to confusing and there is a very
high risk of accidentally using the wrong executable without the
modification or to accidentally overwrite the modification. and b) if you
care so much about performance, you should have used a template style that
does not require communication of velocities (let alone then do computation
with that data without using the result of that. since your computation is
extremely "cheap" such "useless" computations can significantly impact
performance).​
Anyway thanks.
​what you say doesn't make sense. why should you need to set such a large
dmax? the whole point of limiting the maximum displacement is to avoid bad
situations when particles overlap too much. at best, it will take some
additional iterations to get to the minimum.​
in any case, a quick read through the documentation for min_modify reveals
that for your system and requirements, you should use the forcezero
linesearch instead of quadratic. if i use this with a purely repulsive
lj/cut style using a 1 sigma cutoff, it finds the minimum quickly and
reliably.
also, your input doesn't throws an error on the minimize command. do you
have more modifications in you version of LAMMPS that you didn't tell us
about?
is doing correct.
performance).​
Thanks, yes I hacked :slight_smile: as it was easy for me. I like point b), I will
surely try this.
Anyway thanks.
reliably.
about?
No additional modification. Seems if energy is zero in line-minimization,
still it does not stop. So, I did not get any error but higher minimized
energy. When I added this modification in the line_minimization code that
if energy is zero, stop and go back to conjugate gradient code, it gave me
correct output configuration with zero energy for larger dmax 0.3.
Now, coming to the dmax value, you are correct it takes longer time with
low value of dmax, and minimizes. But it does not end in same
configuration, the problem is there. I calculate number of contacts at
lower density and this is very sensitive to dmax. Where contact number
should be zero, I get around 3, as it kept overlap of the order of 10^-12
or so. Lets see. But thanks a lot for so much input.
Regards,
Moumita
As you suggested Axel, forcezero linesearch instead of quadratic works quickly and reliably for purely repulsive potential. It does, Thanks!
Regards,
Moumita
If you are doing minimization with pair DPD, you probably
need to turn off the random force term. I don’t think the
minimizer will work if that is added in every time forces
are evaluated.
