Connecting to MongoDB atlas
I have been trying to set up the MongoDB atlas database for fireworks.
My launchpad looks like the following:
host: mongodb+srv://cluster0-b05rv.mongodb.net/test
port: 27017
username: admin
password: <>
logdir: null
ssl: false
strm_lvl: INFO
user_indices: []
wf_user_indices: []
However, I have been getting the following error when I run lpad reset:
ValueError: FireWorks was not able to connect to MongoDB. Is the server running? The database file specified was /n/home02/zzhu/atomate/config/my_launchpad.yaml.
It only connects if I change the fire /fireworks/core/.launchpad.py around line 149 to the following:
get connection
    #self.connection = MongoClient(host, port, ssl=self.ssl,
    #    username=username,password=password,
    #    ssl_ca_certs=self.ssl_ca_certs, ssl_certfile=self.ssl_certfile,
    #    ssl_keyfile=self.ssl_keyfile, ssl_pem_passphrase=self.ssl_pem_passphrase,
    #    socketTimeoutMS=MONGO_SOCKET_TIMEOUT_MS, connect=False)
    #self.db = self.connection[name]
    #if username:
    #     self.db.authenticate(username, password, source=self.authsource)
    self.connection = MongoClient(host, port, username=username, password=password)
The db.authenticate function always gives me trouble.
I wonder if this is a known issue and if there’s any solution to this?
Zoe Zhu
Hi Zoe,
Based on talking to some colleagues, it seems the db.authenticate() function in pymongo is deprecated. In FWS v1.8.5 (just released now) we changed the authentication code. Let us know if it works for you.
Anubhav
Hi Anubhav,
Thank you so much for your help.
I am still getting an error (but a different one):
pymongo.errors.ServerSelectionTimeoutError: connection closed,connection closed,connection closed
Ziyan (Zoe) Zhu
Ph.D. Candidate
Department of Physics, Harvard University
zz…@g.harvard.edu, [email protected]
(310)-210-0580
And I got this error when I did lpad reset.
Ziyan (Zoe) Zhu
Ph.D. Candidate
(310)-210-0580
Hi Zoe
Do you happen to know what part of the connection code is causing the error? I’m happy to push a fix, just not sure which part of the code is causing problems on your end.
Anubhav
Anubhav
Hi Anubhav,
Sorry I didn’t include all the error messages! See below:
File “/n/home02/zzhu/.conda/envs/atomate_env/bin/lpad”, line 11, in
load_entry_point('FireWorks==1.8.5', 'console_scripts', 'lpad')()
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/fireworks/scripts/lpad_run.py”, line 1147, in lpad
args.func(args)
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/fireworks/scripts/lpad_run.py”, line 148, in reset
lp.workflows.count()))[0].upper() == 'Y':
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/pymongo/collection.py”, line 1766, in count
return self._count(cmd, collation, session)
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/pymongo/collection.py”, line 1563, in _count
with self._socket_for_reads(session) as (sock_info, slave_ok):
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/contextlib.py”, line 81, in enter
return next(self.gen)
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1099, in _socket_for_reads
server = topology.select_server(read_preference)
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/pymongo/topology.py”, line 224, in select_server
address))
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/pymongo/topology.py”, line 183, in select_servers
selector, server_timeout, address)
File “/n/home02/zzhu/.conda/envs/atomate_env/lib/python3.6/site-packages/pymongo/topology.py”, line 199, in _select_servers_loop
self._error_message(selector))
Zoe
Ziyan (Zoe) Zhu
Ph.D. Candidate
(310)-210-0580
Hi Zoe,
Actually, we found an issue in the previous release and pushed a fix in v1.8.6. Let me know if that one works or if you still have problems.
Anubhav
Hi Anubhav,
Thanks for your response. However, I am still getting the same error message when I do lpad reset:
load_entry_point('FireWorks==1.8.6', 'console_scripts', 'lpad')()
args.func(args)
address))
Ziyan (Zoe) Zhu
Ph.D. Candidate
(310)-210-0580
On Wed, Feb 13, 2019 at 5:14 PM Anubhav Jain [email protected] wrote:
Hi Zoe,
On Tue, Feb 12, 2019 at 6:49 PM Anubhav Jain [email protected] wrote:
Hi Zoe
Anubhav
On Tue, Feb 12, 2019 at 3:13 PM Zoe Zhu [email protected] wrote:
Hi Anubhav,
Ziyan (Zoe) Zhu
Ph.D. Candidate
(310)-210-0580
On Tue, Feb 12, 2019 at 4:37 PM Anubhav Jain [email protected] wrote:
Hi Zoe,
port: 27017
username: admin
password: <>
logdir: null
ssl: false
strm_lvl: INFO
user_indices:
wf_user_indices:
get connection
    #if username:
Zoe Zhu
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to [email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
For more options, visit https://groups.google.com/d/optout.
Anubhav
Anubhav
Anubhav
Hi all,
Due to Google groups withholding these messages, I can’t tell if these problems are with FWS v1.8.5 or v1.8.6.
Can you clarify if the problem is still present in FWS v1.8.6?
Anubhav
I realized I had v 1.8.4 installed
Upgrading did not work nonetheless, and I still have a pymongo.error with version 1.8.6 (see below).
I am actually behind a firewall, how can I make sure this is not the problem?
Thank you
$ python
Python 3.6.8 |Anaconda, Inc.| (default, Dec 30 2018, 01:22:34)
import fireworks
print(fireworks.version)
1.8.6
import pymongo
print(pymongo.version)
3.7.2
$ which lpad
/home/mdi0316/anaconda3/bin/lpad
$ lpad -l my_launchpad_testing.yaml get_wflows
File “/home/mdi0316/anaconda3/bin/lpad”, line 10, in
sys.exit(lpad())
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/fireworks/scripts/lpad_run.py”, line 1147, in lpad
args.func(args)
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/fireworks/scripts/lpad_run.py”, line 297, in get_wfs
ids = lp.get_wf_ids(query, sort, args.max, count_only=args.display_format == ‘count’)
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 667, in get_wf_ids
for fw in self.workflows.find(criteria, {“nodes”: True}, sort=sort).limit(limit):
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/cursor.py”, line 1189, in next
if len(self.__data) or self._refresh():
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/cursor.py”, line 1087, in _refresh
self.__session = self.__collection.database.client._ensure_session()
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1563, in _ensure_session
return self.__start_session(True, causal_consistency=False)
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1516, in __start_session
server_session = self._get_server_session()
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1549, in _get_server_session
return self._topology.get_server_session()
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/topology.py”, line 427, in get_server_session
None)
File “/home/mdi0316/anaconda3/lib/python3.6/site-packages/pymongo/topology.py”, line 199, in _select_servers_loop
pymongo.errors.ServerSelectionTimeoutError: ds049170.mongolab.com:49170: timed out
Hi Marco
To make the firewall is not the problem, I would first try connecting to your database using the standard mongo shell (from MongoDB) rather than FireWorks. If you can connect with the mongo shell, then you should (in theory) be able to connect with FWS - so let us know if you can connect with mongo shell but not FWS. If you cannot connect with the mongo shell, FireWorks will also not work. In that case, you will need to work with a system administrator to get that aspect worked out before moving on to FWS…
Anubhav
Anubhav
Dear Anubhav,
as I stated in my original question, yes, I can connect to port 27017
Nevertheless I get two wanings and I am not sure I am really connected
$ mongo
MongoDB shell version v4.0.3
connecting to: mongodb://127.0.0.1:27017
WARNING: No implicit session: Logical Sessions are only supported on server versions 3.6 and greater.
Implicit session: dummy session
MongoDB server version: 2.6.10
WARNING: shell and server versions do not match
Please let me know if you have any suggestion on this
Kind regards
Hi Marco,
I can connect to the testing ds049170.mongolab.com:49170 server using the my_launchpad_testing.yaml document specified in the documentation using the latest FireWorks. So, my guess is that there is a firewall issue that is preventing you from accessing that test database hosted online.
In terms of testing using the “mongo” shell, I meant testing that you can connect to the remote server using the mongo shell. That is, testing to see if you can connect to the ds049170.mongolab.com:49170 server using the mongo shell.
There are some details here:
https://docs.mongodb.com/manual/mongo/
But you can just type the following shell commands:
mongo --username test_user --password testing123 --authenticationDatabase fireworks --host ds049170.mongolab.com --port 49170
MongoDB shell version v3.4.4
connecting to: mongodb://ds049170.mongolab.com:49170/
MongoDB server version: 3.6.6
use fireworks
switched to db fireworks
db.fireworks.count()
2
If those commands do not work on your system (they do on mine), it is almost certainly a firewall problem as those commands just use the mongo shell and not FWS
Anubhav
Note that another way to test the firewall issue is to try the same commands on home network vs a company network.
Anubhav
Hello Anubhav,
I am trying to connect to MongoDB atlas through fireworks. The error is below.
My Fireworks is version 1.8.7.
Please let me know if there is any other information that I can provide that would help.
C:\Users\athre\Miniconda3\Lib\site-packages\fw_tutorials\introduction>lpad reset
File “c:\users\athre\miniconda3\lib\runpy.py”, line 193, in _run_module_as_main
main”, mod_spec)
File “c:\users\athre\miniconda3\lib\runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “C:\Users\athre\Miniconda3\Scripts\lpad.exe_main_.py”, line 9, in
File “c:\users\athre\miniconda3\lib\site-packages\fireworks\scripts\lpad_run.py”, line 1146, in lpad
args.func(args)
File “c:\users\athre\miniconda3\lib\site-packages\fireworks\scripts\lpad_run.py”, line 148, in reset
lp.workflows.count()))[0].upper() == ‘Y’:
File “c:\users\athre\miniconda3\lib\site-packages\pymongo\collection.py”, line 1766, in count
File “c:\users\athre\miniconda3\lib\site-packages\pymongo\collection.py”, line 1563, in _count
File “c:\users\athre\miniconda3\lib\contextlib.py”, line 112, in enter
File “c:\users\athre\miniconda3\lib\site-packages\pymongo\mongo_client.py”, line 1099, in _socket_for_reads
File “c:\users\athre\miniconda3\lib\site-packages\pymongo\topology.py”, line 224, in select_server
address))
File “c:\users\athre\miniconda3\lib\site-packages\pymongo\topology.py”, line 183, in select_servers
File “c:\users\athre\miniconda3\lib\site-packages\pymongo\topology.py”, line 199, in _select_servers_loop
Athreya Ramesh
port: 27017
username: admin
password: <>
logdir: null
ssl: false
strm_lvl: INFO
user_indices:
wf_user_indices:
get connection
    #if username:
Zoe Zhu
Hi Athreya
Sorry but this is not enough information to debug.
Can you first try connecting to Atlas using the pymongo tool directly (and not using FireWorks)? Once you have that working, you can let us know what settings you used to get it to work with direct pymongo connection that are not working when you try it with FireWorks.
On Tuesday, March 26, 2019 at 3:59:21 PM UTC-7, Athreya Ramesh wrote:
Hello Anubhav,
main”, mod_spec)
args.func(args)
address))
Athreya Ramesh
port: 27017
username: admin
password: <>
logdir: null
ssl: false
strm_lvl: INFO
user_indices:
wf_user_indices:
get connection
    #if username:
Zoe Zhu
Hi everyone,
Have you resolved your issue yet? Could you please try adding one line:
ssl: True
to your my_launchpad.yaml file?
Sometimes it might be an issue with the certificate that your mongodb hosting provider uses. I had a similar issue like all yours, and was able to resolve it by setting the ssl option to True.
Fengyu Xie
Hi Fengyu,
Setting ssl: True does not work for me. This error occurred
pymongo.errors.OperationFailure: Authentication failed., full error: {‘ok’: 0, ‘errmsg’: ‘Authentication failed.’, ‘code’: 8000, ‘codeName’: ‘AtlasError’}
Could you help me with this?
Setting ssl:True did not solve the problem, but then when I added authsource: admin to the my_launchpad.yaml file, then it worked for me.
My my_launchpad.yaml file in it’s final form looks like this:
host: mongodb+srv://<>.mongodb.net
port: 27017
username: <>
password: <>
ssl_ca_file: null
logdir: null
strm_lvl: INFO
user_indices: []
wf_user_indices: []
ssl: True
authsource: admin
I am meeting a similar problem. How to solve it?
Thanks.
I have installed MongoDB and Fireworks, which can work.
but, lpad -l my_launchpad_testing.yaml get_wflows
my_launchpad_testing.yaml content:
host: ds049170.mongolab.com
port: 49170
username: test_user
password: testing123
error:pymongo.errors.ServerSelectionTimeoutError: ds049170.mongolab.com:49170: timed out, Timeout: 30s, Topology Description: <TopologyDescription id: 6239472928138c21255e452b, topology_type: Unknown, servers: [<ServerDescription (‘ds049170.mongolab.com’, 49170) server_type: Unknown, rtt: None, error=NetworkTimeout(‘ds049170.mongolab.com:49170: timed out’)>]>
