Dear All,
I am working with the given example on the thermal conductivity calculation example using the Green-Kubo formula. I noticed an inconsistency between the equation and the unit conversion in the example.
considering the integral;
\frac{V}{3kb*T^2} \int \langle J \cdot J \rangle dt
Now, if we don’t divide the J_{computed} by the volume, which is required by the LAMMPS documentation to get the actual J, the GK formula is;
\frac{V}{3kb*T^2} \int \frac{1}{V^2} \langle J_{computed} \cdot J_{computed} \rangle dt =
\frac{1}{3V kbT^2} \int \langle J_{computed} \cdot J_{computed} \rangle dt
the variable scale is putting volume in the denominator of the integral coefficient, which is for the case we have not already divided J_{computed} by the volume. However, the script has three lines doing so before the GK calculation.
My question is, am I missing something in my logic?
Amir Behbahanian
Mechanical & Aerospace Engineering
Utah State University
4110 Old Main Hill
Logan, Utah 84322
