Hello everyone,
in this Publication (http://dx.doi.org/10.1088/0965-0393/20/3/035019), NEB Calculations are carried out, where only the Z-Coordinate of the NEB-Atoms is controlled by the NEB Calculations, whereas the X and Y Coordinate of the neb-atoms (as well as the (X,Y,Z) - Coordinates of the Non-NEB Atoms) are controlled by the conventional minimizer.
At least according to the lammps documentation, there is no possibility described, to achieve this behaviour. My attempt of using fix ${fix-id} neb-atoms setforce 0.0 0.0 NULL lead to no movement in x & y direction of the neb-atoms during the NEB-Calculations.
So is there a way to achieve the described behaviour of limiting the NEB to single Degrees of Freedom (and not to atoms only) in Lammps implemented currently?
Warm Regards
Benedikt
