#------ initialization ------
boundary s s s
atom_style atomic
neighbor 2.0 bin
#-----geometric variable-----
variable scale equal 1.0
variable tdamp equal 10
variable file string 0_twin
variable theta equal 20*3.1415926/180
variable z_scale equal 375*${scale}
variable z_1 equal ${scale}*124.5
variable z_2 equal ${scale}*145.5
variable z_3 equal ${scale}*175.5
variable z_4 equal ${scale}*217.5
variable z_5 equal ${scale}*240
variable z_6 equal ${scale}*310
variable low_1 equal 105*${scale}
variable low_2 equal 87.9*${scale}
variable low_3 equal 168.54*${scale}
variable low_4 equal 250.02*${scale}
variable low_5 equal 332.34*${scale}
variable low_6 equal 415.5*${scale}
variable high_1 equal 45*${scale}
variable high_2 equal 45.9*${scale}
variable high_3 equal 42.54*${scale}
variable high_4 equal 40.02*${scale}
variable high_5 equal 38.34*${scale}
variable high_6 equal 37.5*${scale}
variable cone_hi equal 300*${scale}
#------ generation ------
lattice fcc 3.6150 orient x 1 1 1 orient y 1 1 -2 orient z -1 1 0
region sc prism -15 360 -140 140 -210 210 0.0 0.0 0.0 units box
create_box 3 sc
region model_1 prism -${z_scale} ${z_1} -140 140 -375 375 0.0 0.0 0.0 units box
region model_2 prism ${z_1} ${z_2} -140 140 -375 375 0.0 0.0 0.0 units box
region model_3 prism ${z_2} ${z_3} -140 140 -375 375 0.0 0.0 0.0 units box
region model_4 prism ${z_3} ${z_4} -140 140 -375 375 0.0 0.0 0.0 units box
region model_5 prism ${z_4} ${z_5} -140 140 -375 375 0.0 0.0 0.0 units box
region model_6 prism ${z_5} ${z_6} -140 140 -375 375 0.0 0.0 0.0 units box
create_atoms 1 region model_1
create_atoms 1 region model_3
create_atoms 1 region model_5
#-- twin --
lattice fcc 3.6150 orient x -1 -1 1 orient y 1 1 2 orient z -1 1 0
create_atoms 2 region model_2
create_atoms 2 region model_4
create_atoms 2 region model_6
#--------rotation----------------
group wtf_1 region model_1
group wtf_2 region model_2
group wtf_3 region model_3
group wtf_4 region model_4
group wtf_5 region model_5
group wtf_6 region model_6
group nvtpart union wtf_1 wtf_2 wtf_3 wtf_4 wtf_5 wtf_6
displace_atoms nvtpart rotate 0 0 0 0 1 0 -90
#-----shape------
region fuck_1 cone z 0 0 ${low_1} ${high_1} 0 ${cone_hi} side out units box
region fuck_2 cone z 0 0 ${low_2} ${high_2} 0 ${cone_hi} side out units box
region fuck_3 cone z 0 0 ${low_3} ${high_3} 0 ${cone_hi} side out units box
region fuck_4 cone z 0 0 ${low_4} ${high_4} 0 ${cone_hi} side out units box
region fuck_5 cone z 0 0 ${low_5} ${high_5} 0 ${cone_hi} side out units box
region fuck_6 cone z 0 0 ${low_6} ${high_6} 0 ${cone_hi} side out units box
delete_atoms region fuck_1
delete_atoms region fuck_2
delete_atoms region fuck_3
delete_atoms region fuck_4
delete_atoms region fuck_5
delete_atoms region fuck_6
lattice diamond 3.57
region top prism -185 45 -105 105 302 312 0.0 0.0 0.0 units box
create_atoms 3 region top
region down prism -140 140 -140 140 -15 0 0.0 0.0 0.0 units box
create_atoms 1 region down
#------ mass ------
mass 1 63.550
mass 2 63.550
mass 3 12.0096
#------ force field ------
pair_style hybrid eam/alloy tersoff lj/cut 3.615
pair_coeff * * eam/alloy Cu_zhou.eam.alloy Cu Cu NULL
pair_coeff * * tersoff SiC.tersoff NULL NULL C
pair_coeff 1*2 3 lj/cut 0.001034 2 3.615
#------ computation ------
compute peratom all pe/atom
#------ minimize ------
variable t equal "time"
variable temp equal "temp"
variable pe equal "pe"
group top1 type 3
group down1 region down
displace_atoms top1 rotate 0 0 0 0 1 0 20
fix xwalls all wall/reflect xlo EDGE xhi EDGE
fix ywalls all wall/reflect ylo EDGE yhi EDGE
fix zwalls all wall/reflect zlo EDGE zhi EDGE
delete_atoms overlap 0.1 all all
fix top top1 setforce 0.0 0.0 0.0
dump 1 all custom 1000 ${file}_mini_*.dump id type xu yu zu c_peratom
#dump_modify 1 sort id scale no
thermo 500
thermo_style custom step temp pe
min_style cg
minimize 1.0e-12 1.0e-5 1000000 100000
undump 1
#------ stage 4 ------ DEFORMATION
fix freeze down1 setforce 0.0 0.0 0.0
fix 1 all nve
fix 2 all temp/berendsen 100.0 100.0 ${tdamp}
dump 8 all custom 500 ${file}_*.dump id type xu yu zu c_peratom
dump_modify 8 sort id
thermo 500
run 100000
undump 8
thermo 500
min_style cg
undump 1
velocity all create 200.0 4928459
fix 2 all temp/berendsen 200.0 200.0 ${tdamp}
thermo 500
run 100000
unfix 2
undump 8
thermo 500
min_style cg
undump 1
velocity all create 300.0 4928459
fix 2 all temp/berendsen 300.0 300.0 ${tdamp}
thermo 500
run 100000
unfix 2
undump 8
write_restart ${file}_thermo.restart
thermo 50
min_style cg
minimize 1.0e-12 1.0e-8 1000000 100000
undump 1
restart 1000 restart_nt-Cu_sametemp_*.restart
thermo 500
thermo_style custom step temp pe etotal pxx pyy pzz fmax
run 100000
unfix 2
undump 8
write_restart ${file}_final.restart
Here is the video I made from the output
https://drive.google.com/file/d/1aSCqPMBHx_kpS4cieeMsXxhVhjnaPcWJ/view?usp=sharing
As you can see, it’s unstable.
How do I fix it by modifying the input
- List item
