Controlling the Number of Processors in exciting_smp
Hi everyone,
I’m running exciting_smp (the shared-memory multiprocessing version) and trying to control the number of processors it uses. I’ve set OMP_NUM_THREADS=4 in my .bashrc to limit it to 4 threads. However, when I monitor the system while it’s running, I notice it seems to use more than that—around 6 or 7 processors at times.
Is there a way to ensure it only uses the specified number of processors, or am I missing something in the configuration? Any insights on controlling processor usage for exciting_smp would be greatly appreciated!
Thanks!
Hi @sareh , setting OMP_NUM_THREADS in the .bashrc is a bad idea. This is going to affect all apps launched from your shell. It’s better to just export OMP_NUM_THREADS=4 on a per-session basis.
In my experience, openBLAS is extremely greedy when it comes to threads, and doesn’t necessarily respect OMP_NUM_THREADS. Try setting export OPENBLAS_NUM_THREADS=1. Similarly, MKL threads can be controlled with MKL_NUM_THREADS.
It’s likely to be whatever BLAS flavour you’re using that’s using the extra threads.
Cheers,
Alex
Thank you so much, it works well.
Hi, could you please provide me with the command ( steps) to make use of mpirun during running execution
You’re using the wrong binary. See INSTALL.md:
By default, the mpiandsmp and smp versions of exciting are built, where mpiandsmp refers to a binary with both MPI and openMP parallelism enabled.
Running with MPI is the same for any program compiled with MPI support:
mpirun -np 4 exciting_mpismp
thanks , …
what about 2D , input files ,
