Hello LAMMPS users,
I am currently simulating the deposition of carbon atoms onto a silicon substrate using units metal in LAMMPS.
The deposition command I am using is:
lammps
CopyEdit
region slab block 0 5 0 5 5 8 units lattice
fix 5 addatoms deposit 2000 2 25 12345 region slab near 3.0 vx 0 0 vy 0 0 vz -30.0 -30.0
To estimate the incident kinetic energy (KE) of the depositing carbon atoms, I am using the standard formula:
KE=12mv2\text{KE} = \frac{1}{2} m v^2KE=21mv2
where:
- mmm is the atomic mass in amu (for carbon, 12.0),
- vvv is the velocity in Å/ps,
- and the result is expected in eV since I’m using
metalunits.
My questions are:
- To compute the kinetic energy in eV, do I need to convert the mass and velocity to SI units first, or does this formula work directly under
metalunits? - If I want to deposit carbon atoms with incident kinetic energies ranging from 10 eV to 100 eV, what would be the appropriate velocity values I should assign in the
fix depositcommand?
Any clarification or advice would be greatly appreciated.
Thank you!
