Hi LAMMPS users,
Want to share some small auxiliary pieces of code.
In case if some one need to convert restart files into OBJ files - I
wrote a script which does it (may be imperfect, but works). So it gets
angles and saves them as triangles in OBJ file. Also let me know if
reinvented a bicycle. If someone is interested in using it, ask me
about improvements that might be done or I could dump to OBJ files
instead of doing post-processing (not sure that it is a better way).
The idea is to use Blender or similar tools for rendering of the
resulting collection of OBJ files, but I didn't wrote a script for
that yet.
https://github.com/KirillLykov/lammps-extensions/blob/master/scripts/restart2obj.py
I also shared some other code, like class which computes some
statistical properties of the liquid in a specified region - I create
a custom communicator there
https://github.com/KirillLykov/lammps-extensions/blob/master/utils/value_calculator.h.
Also class which counts molecules and creates a continuum index for
them (long time ago extracted it from somewhere) -
https://github.com/KirillLykov/lammps-extensions/blob/master/utils/molecule_counter.h
Routines which gather stl containers (it can be generalized by
request) - https://github.com/KirillLykov/lammps-extensions/blob/master/utils/gather_containers.h
