I am trying to find information about the relative costs of LJ, Morse, and EAM potentials, especially the latter two.
I know that LJ is found to be 2.3x faster than EAM in a paper by Plimpton.
In my own tests, I find that potentials are LJ 1x, Morse 4.4x, and EAM 3.7x fast.
I use a 3D FCC structure of ~10K Copper atoms that are already statically minimized and measure the elapsed time for 1K dynamic iterations. I use the Cu_u3.eam potential.
I suspect that Morse should not be expensive as EAM, or is it?
please note, that these kind of comparisons cannot be generalized in this
way.
3.7x fast.
you mean slower, right?
things are never that easy. EAM is often used with a shorter cutoff
compared to LJ and Morse, so it doesn't not only matter how fast you can
compute the interaction between a single pair of atoms, but also how many
pairs you have to consider. keep in mind that the number of atoms in a
(cutoff) sphere grows O(N**3) with the (cutoff) radius.
there also is the (minor impact) of the choice of compiler and compiler
flags as well as CPU hardware or math library. LJ is more affected by
memory bandwidth, than EAM or Morse, who have more expensive to compute
potential functions.
I don’t know what “paper by Plimpton” you are referring to.
You can find benchmark results for various potentials
and tarballs with the files that ran them at this link:
http://lammps.sandia.gov/bench.html#potentials
