Keep asking the list, especially if its a documented example. I have never run this case.
I took a look at the nemd simulation. I do not actually want to deform my box.
The output read that I had to use a triclinic box. Changing my box style to prism deforms the box; however I would like to keep the box rectangular.
I did, however, experiment with the fix viscosity command. Is there perhaps a way to use that command to obtain slip and no slip? From what I can tell, my liquid is indeed obtaining a shear force from the wall.
My code is:
2d friction simulation
dimension 2
boundary p s p
units lj
atom_style atomic
neighbor 0.3 bin
neigh_modify delay 5
create geometry
lattice hex 0.9
region box block 0 40 0 10 -0.25 0.25
create_box 4 box
mass 1 1
mass 2 1
mass 3 1
mass 4 1
atom regions
region lo-fixed block INF INF INF 1 INF INF
region hi-fixed block INF INF 9 INF INF INF
region noboundary union 2 lo-fixed hi-fixed side out
region circle sphere 20 5 0 1.5
region nocircle sphere 20 5 0 1.5 side out
#region nocircle sphere 20 5 0 3 side out
region flow intersect 2 noboundary nocircle
create 2 surfaces with asperities
create_atoms 1 region lo-fixed
create_atoms 1 region hi-fixed
create_atoms 3 region circle
create_atoms 2 region flow
#delete_atoms porosity flow 0.01 482793
LJ potentials
pair_style lj/cut 1.2
pair_coeff * * 1.0 1.0 1.2
group lo-fixed region lo-fixed
group hi-fixed region hi-fixed
group boundary union lo-fixed hi-fixed
group mobile region flow
group circle region circle
initial velocities
compute new mobile temp/partial 0 1 0
velocity mobile create 0.1 482748 temp new
velocity hi-fixed set 3.0 0.0 0.0 sum yes
velocity lo-fixed set -3.0 0.0 0.0 sum yes
fixes
fix 1 all nve
fix 2 boundary setforce 0.0 0.0 0.0
fix 3 circle temp/rescale 200 0.1 0.1 0.02 1.0
#fix_modify 3 temp new
fix 4 mobile temp/rescale 200 1.0 6.0 0.02 1.0
fix 5 all viscosity 100 x z 20
Run
timestep 0.0015
thermo 100
thermo_modify temp new
dump 1 all atom 500 dump.friction
dump 2 all image 100 image.*.jpg type type &
zoom 1.6 adiam 1.2
dump_modify 2 pad 6
run 100000
Your box will remain rectangular with proper remapping. The deformation is merely a means to induce momentum transfer between period images. Such systems are “shear-periodic.” Lees-Edwards boundary conditions are intuitively easier to understand, and equivalent. Check them out.
You need to ask the question of what you are trying to do. Whats the point of obtaining a result you don’t understand or necessarily require.
Read that fix documentation more carefully.
If you can pose some well-framed specific questions, I or someone else can answer your questions more directly. But if all you’re looking to do is replicate phenomenological behaviour specific to some system, I implore you to read my previous responses on slip behaviour more carefully, and do the ground work.
Lammps is usually not intended to replicate phenomonology. You can always get a result from physically irrelevant hacking. It is a tool to simulate physical systems, where phenomological behaviour may develop as a result of physically relevant system parameters and interaction models.
