Hi everyone!
I’m a new user of Lammps, but I’ve searched the mail list and the documentation extensively for my problem so hopefully my problem hasn’t been asked before (although I suspect it might still be a RTFM-issue).
Trying simulate liquid NaCl I noticed that even below the boiling temperature (p = 1 bar) the radial distribution function was that of a gas. The same thing happened for both
pair_style born/coul/long 7.6 15.0 (I used a previous answer from the mailing list that treated NaCl and modified it)
or using a hybrid/overlay pair_style with the repulsive part being a table taken from Kittels Introduction to Solid State Physics (page 62 of 8th edition paperback) and a coul/long term.
I used pair_write from the below test code to see what kind of potential was being calculated (version: LAMMPS 64-bit 15Apr2020).
Setup
atom_style charge
Na atoms
lattice fcc 5.64 origin 0 0 0
region box block 0 10 0 10 0 10
create_box 2 box
create_atoms 1 box
Cl atoms
lattice fcc 5.64 origin 0.5 0 0
create_atoms 2 box
Other settings
mass 1 28.990
mass 2 35.453
set type 1 charge +1.0
set type 2 charge -1.0
Potentials
pair_style coul/cut 10.0
pair_coeff 1 1
pair_coeff 1 2
pair_coeff 2 2
pair_write 1 1 1000 r 0.2 10.2 table1.txt coul11
pair_write 1 2 1000 r 0.2 10.2 table2.txt coul12
Plotting the energy and force values for the tables gave the same exact curves and both were always positive. I also tried the same with born/coul/long, and coul/long but the plotted values were still positive.
In the documentation for pair_write it states “If the pair potential is computed between charged atoms, the charges of the pair of interacting atoms can optionally be specified. If not specified, values of Qi = Qj = 1.0 are used.” I’m not sure if the output from pair_write only takes into account Qi=Qj = 1.0 interactions even though I set the charges in the code or if in fact the potential is always positive, no matter the charges in the pair, which might explain why the system does not form a liquid even below the boiling point. Am I missing something?
William Green
