I am running with keyword opti conp, and I found that it is very time-consuming, could I change those parameters myself? For example, change the Maximum number of calculations to 100?
You can reduce the number of cycles or change any of the settings. All the options are given in the help text. Of course if it’s taking a long time then this probably means you have a large system and so running in parallel is perhaps the only solution.
