Hi lammps users,
Now, I am performing simulations of ICE melting with TIP4P/ICE model.
I am doubt about the parameter setting of Coulombic cutoff of this model.
In the LAMMPS manual (http://lammps.sandia.gov/doc/Section_howto.html#howto_8), a cutoff of Coulomb is
used, which suggests a cutoff model, such as pair_style lj/cut/tip4p/cut.
However, in the original work of TIP4P/ICE ((J Chem Phys, 122, 234511 (2005); http://dx.doi.org/10.1063/1.1931662)),
the long range Coulombic interaction was considered using Ewald summation technique (EST).
So, my question is should I consider the long-range electrostatic force (with PPPM) or without consideration for TIP4P/ICE
model in LAMMPS.
Hi lammps users,
Please read the text more carefully. It says that you can use either. The original tip4p was, of course, parameterized for cutoff, but that is not the model you want.
Thanks for you reply.
The original tip4p/ic was not setting cutoff for electrostatic force((J Chem Phys, 122, 234511 (2005); http://dx.doi.org/10.1063/1.1931662)),
But in lammps manual, there is a cutoff of Coulomb with a ciatation of this orignal paper (as shown above). The parameters setting are different with its citation, that is what I am puzzling.
Bests,
NIngwei
Phys, 122, 234511 (2005); http://dx.doi.org/10.1063/1.1931662),
i didn't say that. i referred to the original TIP4P paper to which
model you were pointing with the URL to the LAMMPS manual. that
segment clearly says first: you can use either lj/cut/tip4p/cut for a
cutoff model or lj/cut/tip4p/long and pppm/tip4p for a long-range
electrostatics based model. *then* it lists the parameters for the
original tip4p model (with reference to the jorgensen paper), which
*is* a cutoff model, then tip4p/ice, then tip4p/2005 and tip4p/ew,
i.e. the version of the original tip4p reparameterized for long-range
electrostatic. all logical, systematic, and not confusing (to me) at
all.
where exactly are they different?
what i find more puzzling is your ability to misread documentation
(and e-mails). could it be that your screen is dirty and needs to be
cleaned?
